Go Back   Automotive Forums .com Car Chat > Mitsubishi > 3000GT/Stealth
Thread Tools Search this Thread
Old 11-20-2003, 05:39 AM   #1
yaaiyaai
Send a message via ICQ to yaaiyaai
Question can 4g63 engine (from evoIII) fit in Gto chasis?
can a 4g63 engine (from evoIII) fit into a Gto chasis, without modifying engine mounting? i mean nicely fit in.
what engines can fit into a gto chasis without modifying engine mounting?
Mitsubishi GTO 3000 original uses 6G72 Twin Turbo, and
Mitsubishi Evolution 3 originally uses 4G63T.
yaaiyaai is offline   Reply With Quote
Old 11-20-2003, 05:48 AM   #2
youngvr4
STREET RACING GURU
youngvr4's Avatar
i don't know, and i don't think you wanna do that anyway, the reason the evo-8 is so fast is hp to weight and electronics etc, you would need more than 270 hp to pull the heavy 3800lb beast. thats why they are 320hp.
youngvr4 is offline   Reply With Quote
Old 11-20-2003, 03:32 PM   #3
talskinyguy
Send a message via AIM to talskinyguy
You can fit it in there, but you will have to moddify some stuff. You best bet if you were going with this project would be to buy an old 90-94 turbo AWD DSM and pull the engine and drivetrain out of it. Rebuild the engine and trans, and custom make some motor mounts. After you get it and the drivetrain somehow hooked up, you will have to get a custom drive shaft made.
After you go through all that work you will most likeyl have to replace the transmision pretty regualarly because the DSM transmision is no designed to pull a 3800lb car. Hell, they blow up just pulling the DSM when ya get the HP up there.
talskinyguy is offline   Reply With Quote
Old 11-22-2003, 04:15 AM   #4
yaaiyaai
Re: can 4g63 engine (from evoIII) fit in Gto chasis?
a 3.0 liter vehicle roadtax is hell expensive in my country, also fuel consumption is high, i probably won't drive it everyday.
is there an option to fit in smaller capacity engine into a gto chasis without modifying engine mounting? (like what happen to evo engine into lancer, or evo engine into fto, yes, they are nicely fit in)
***oh yeah, above 220 hp should be enough for me
*** i am planning to get an aging gto and swap the heart.
Old 11-22-2003, 08:31 PM   #5
Killbilly
The only engine I think that *might* fit..but I have my doubts is the 6G73 2.5L V6.
But if a 3.0l is so expensive to register...why get one?
I'd be getting a smaller car that's more potent. The GTO's albeit they're nice and all..but they're heavy and tend to use a lot of fuel.
I think you'd be wasting a lot of money to be honest...but hey it's your money and it's not up to me. Feel free to disregard my opinion.
Killbilly is offline   Reply With Quote
Old 11-23-2003, 12:53 AM   #6
talskinyguy
First off, an evo engine will not, I repeat, will not drop into a lancer. It will require lots of fabrication. An evo and a lancer are different vehicles that are created on the same platform and share the same skin. Under the skin they are drasticly different. A lancer does 0-60 in 10 seconds, and an evo does 0-60 in 5, more than an engine swap.
I cant think of an engine that you could swap into a gto that would give you better gas milage, I think its time to look at other cars.
Old 11-24-2003, 10:59 PM   #7
pjk3_VR4
Ooooo, bad idea. The 4g63 will not produce the kind of torque needed to push around the heavy ass GTO remember HP and Torque are two different things. Even with the turbo it would suck. It would be slow and lethargic and an all around disapointment. You are better off going with a smaller displacement car all together. I do not know what you budget is, but why not get the EVO or an older Eclipse GSX or Talon TSI. Good strong inline fours with the all wheel drive and all.
pjk3_VR4 is offline   Reply With Quote
Old 11-25-2003, 12:49 AM   #8
youngvr4
STREET RACING GURU
youngvr4's Avatar
i agree
Old 11-25-2003, 03:59 AM   #9
talskinyguy
Eclipse and talon are USDM only, they dont exsist in other coutrys. He could look into the fto though.
Old 11-25-2003, 09:03 AM   #10
Blaze420
Send a message via MSN to Blaze420
Dude, do not put that engine in your GTO you will ruin it. The stock 3.0L is much better.
Blaze420 is offline   Reply With Quote
Old 11-25-2003, 03:55 PM   #11
Killbilly
You can get 600hp plus out of that stock motor...so spend the money on modding it
Old 11-25-2003, 08:26 PM   #12
pjk3_VR4
600, I am shooting for at least a grand. Shouldn't be that hard either. Although I am looking at spending like 25-30 Gs on my engine alone in the next few years. Not to mention the Tranny and drivetrain. Wish me luck !!!!!!
Old 11-26-2003, 12:51 AM   #13
Killbilly
yeah you could get 1000hp!
Old 11-26-2003, 01:10 AM   #14
yaaiyaai
thanks to all. appears that i can get a gto till when i can afford a 3.0L vehicle. i will stick to my bb1 for the moment.
yes, people here convert lancer into evo4, 5, 6, transplanting everything they got in evo used front cut and used rear cut from japan. everything nicely fit in. however, chasis rigidity remains lancer's. total price is about half a new original evo. here in malaysia.
Old 11-26-2003, 09:25 AM   #15
talskinyguy
I never said it couldnt be done, I said that its not a drop in replacement.
Bookmarks
Search this Thread:
