Go Back   Automotive Forums .com Car Chat > BMW > 3 Series
Old 02-08-2012, 02:32 AM   #61
goodonehehe
Re: How to Program the BMW key
BMW KEy Programmer , you can go to the site to see the prodcuts
goodonehehe is offline   Reply With Quote
Old 11-05-2012, 10:53 PM   #62
zeozaza
Originally Posted by stephny View Post
This events is for rebooting the key fob for the operation of centred locking and alarm on a most of the marque in most cases does not encompass the immobiliser. If any person needs further info email delight with full info on vehicle.
are you using Google translator ?
zeozaza is offline   Reply With Quote
Old 12-12-2012, 12:22 AM   #63
JayJan
I am not sure there is one single way to program the BMW key fob as most sites out there conflict. I did find one reference listing a bunch so maybe try these out (found at programcarremotes.com BMW link here http://programcarremotes.com/bmw/bmw...e-programming/
To program the key fob for the early model BMW 3 series including the 318 you have to
start with all doors, trunk and hood closed.
There are several different methods to try for the BMW 3Series so you may have to try more
than one. TIP – if one method fails the first time, try it a second time before moving on
to a new method as they can be tricky to get the steps right
METHOD ONE
Step one – Open the Trunk
Step two – get in the drivers side of the vehicle and close the door
Step three – insert the key into the ignition and turn it ‘ON’ and ‘OFF’ five times ending in the ‘OFF’ position.
Your car should indicate that it is ready for programming by emitting a loud ‘chirp’ noise.
Step four – open and close the drivers door (but stay in the seat)
Step five – press any button on the key fob.
The light should flash indicating that programming has been succesful
Step six – repeat steps three and four again for other remotes your wish to program.
Step seven – when you have finished programming key fobs, leave the door open, get out and close the trunk and then close the drivers door.
Your car should indicate that it has completed programming mode by emitting another loud ‘chirp’ noise.
METHOD TWO
Step one – get in the drivers side of the vehicle and close the door
Step two – insert the key into the ignition and turn it ‘ON’ and ‘OFF’ five times ending in the ‘OFF’ position.
Step three – remove the key from the ignition and hold down the UNLOCK button for 15 seconds while pressing the LOCK button three times rapidly.
Step four – release both buttons
Your car should indicate that the key fob has been programmed by cycling the door locks.
METHOD THREE
this method requires at least one working key fob. If it doesn’t work the first time switch the order of the keys.
Step two – insert the key into the ignition and turn it quickly from ‘ON’ to ‘OFF’. All the rest of the steps MUST occur in 30 seconds or less.
Step three – remove key #1 and hold it up near the roof on the drivers side by your shoulder (this is where the reciever is located)
Step four – hold down the UNLOCK button for 15 seconds while pressing the LOCK button three times rapidly.
Step five – release the unlock button
Step six – repeat step three, four, five fast for key #2.
JayJan is offline   Reply With Quote
Old 12-19-2012, 04:17 AM   #64
fordcars
I have own care 2003 X5, I need to program the key to lock and unlock doors. please let me know Thanks. please visit my information BMW repair
fordcars is offline   Reply With Quote
