Go Back   Automotive Forums .com Car Chat > Nissan > General Discussion
Old 02-29-2012, 06:43 PM   #1
snowking67
2002 Nissan Maxima GLE Dash warning lights coming on
I just went through a car wash and my Traction Control, Slip, and ABS lights came on about 5 minutes later. The code said it was the left rear speed sensor. We cleaned it up and everything was fine for a week and now I drove through a small puddle at low speed and all the lights came back on again. Brakes are working fine. I am suspicious about it being just the rear wheel sensor. Would one wheel sensor make all the lights come on like that? Is it possible something else is getting wet to cause this problem? I don't want to by a $200 sensor and find out it's something else. It seems to be something getting wet causing a short. Any ideas?
snowking67 is offline   Reply With Quote
Old 02-29-2012, 07:00 PM   #2
tempfixit
Re: 2002 Nissan Maxima GLE Dash warning lights coming on
Have you inspected the wiring away from the wheel for broken and or bare wires?
tempfixit is offline   Reply With Quote
Old 03-01-2012, 08:23 PM   #3
snowking67
Yes, I had my mechanic look at it and he couldn't find anything.
Old 03-01-2012, 08:42 PM   #4
tempfixit
Do the lights go off in time or are they consistently on??? Have you tried dielectric grease on the sensor wiring harnnes connector.
Old 03-02-2012, 03:48 PM   #5
snowking67
The lights basically stay on until I shut the car off and restart it. It has only happened a couple times in the last week and a half. Where would I find the wiring coupler your talking about? Is it possible that just one wheel sensor would make all those lights come on at the same time?
Old 03-02-2012, 07:34 PM   #6
tempfixit
Yes 1 sensor will cause the lights to come on. To find the harness and sensor connector follow the wiring from the sensor on the wheel axle towards the frame/body, I would guess about 20 inches from the wheel.
Here is a link for what the sensor and its wiring looks like.
http://www.oreillyauto.com/site/c/de...0165&ppt=C0009
Old 11-17-2012, 07:21 AM   #7
Max144
may be while washing your car you drop some water in wire or on sensor and now its disturbing your car computer. if dried all the water then please wait for some time because when the water will dry naturally then the lights will work again properly.
[Spam signature file links removed by moderator]
Max144 is offline   Reply With Quote
2002 ABS and Brake lights coming on? Black_Blade Windstar 19 05-03-2011 11:59 AM
Dash warning lights coming on & very bad shaking car/sterinwheel when I brake 70km/h? danacon Grand AM 7 06-23-2009 05:34 PM
Cadillac Deville Dash Warning Lights all come on! footballmom78 Deville 1 02-05-2009 03:23 PM
1999 Nissan Maxima GLE recommended tire pressure BlueMax Tires and Wheels 3 07-16-2003 05:08 PM
2001 Nissan Maxima GLE Price GhettoMAX Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 08-06-2001 12:59 PM
