Go Back   Automotive Forums .com Car Chat > Ford > Contour
Old 02-04-2004, 01:41 PM   #1
Popsmear
Thumbs down Oxy Sensor/CheckEngineLight/Major gas Problem
I do not have autozone codes handy, the machine is down at the shop for a week or two, but this problem is driving me crazy and costing me a nice amount of money.
98 Contour Sport
99,927 Miles
My check engine light is ON.
I assume it is the Oxy Sensor, though, thats just an assumption.
My gas mileage has gone WAY downhill. I used to use half a tank a week.
Now it is half a tank every 2 days, if im lucky.
I also used to use 89octane, but now with prices so high and my need to refuel so often I use 87.
I was thinking about taking it into the shop, since it probably needs more work (tune up, so on and so forth).
Any ideas?
Popsmear is offline   Reply With Quote
Old 02-04-2004, 01:45 PM   #2
Popsmear
Re: Oxy Sensor/CheckEngineLight/Major gas Problem
I will actually drive out to a different autozone tonight, and get the codes.
Old 02-05-2004, 11:53 AM   #3
beyondloadedSE
AF Ford Contour-Advisor
beyondloadedSE's Avatar
sounds like the symptons of a rich 02 sensor to me. Btw, 87 octane will work perfectly fine in your car.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
beyondloadedSE is offline   Reply With Quote
Old 02-05-2004, 12:46 PM   #4
Popsmear
Yeah, I got the code
P0420 - The PCM has detected that the catalyst system efficency for bank 1 is below threshold for the current engine operating conditions. (Bank 1 indenifies the location of cylinder #1, while bank 2 indentifies the cylinders on the opposite bank)
So I bought the OS sensor for before the catilytic converter.
Will be putting it in shortly, and hopefully that will fix my problem.
Thanks for your help
Old 03-15-2004, 09:16 PM   #5
nav6412
Re: Re: Oxy Sensor/CheckEngineLight/Major gas Problem
did the os sensor work I have a 95 with the same gas milage and hard starting frist thing in the morning
nav6412 is offline   Reply With Quote
Old 10-03-2006, 01:04 AM   #6
phreaq
phreaq's Avatar
The forum is more helpfull when you write back, letting everyone know if it fixed the problem.
phreaq is offline   Reply With Quote
Old 10-03-2006, 09:40 AM   #7
beyondloadedSE
holy old thread batman!
btw, if you want a helpful forum, contour.org is the only contour forum, period. This one pretty much sucks.
"The CEG Nazi"
www.contour.org
Old 10-03-2006, 09:44 AM   #8
pre98zetec
pre98zetec's Avatar
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
you should fix the link in your sig, it goes to the old forums.
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
pre98zetec is offline   Reply With Quote
Old 10-03-2006, 11:21 AM   #9
beyondloadedSE
done!
"The CEG Nazi"
www.contour.org
oxy sensor 96 caravan..poor milege roonie Caravan | Voyager 2 06-08-2014 11:18 AM
99 grand am se 2.4 Oxy Sensor Problem ddrdan Grand AM 2 09-14-2009 03:03 PM
96 grand car.fuel economy...oxy sensor???? roonie Caravan | Voyager 4 12-18-2004 10:56 AM
oxy.sensor 88 DAVE K Caravan | Voyager 3 08-04-2004 06:43 PM
Oxy Sensor Problems! justins Passat 2 12-31-2003 06:31 PM
