| Latest | 0 Rplys |
Car Modeling Share your passion for car modeling here! Includes sub-forum for "in progress" and "completed" vehicles. |
07-08-2012, 07:24 PM | #1 | |
Drilling holes in PE
Hi all,
As i started with the Lotus 99T and i'm using the Studio27 PE set wich included the front and rear end plates. I want to use the end plates, but there are no markings or holes to attach the middle of the end plates. So i want to drill some holes in it so i can attach it to the plastic wing from the Tamiya kit. Is it possible? Any advice would be welcome. Thanks in advance. Best regards, Lesley |
07-08-2012, 09:58 PM | #2 | |
Image Hosting Exceeded
Re: Drilling holes in PE
Sure, drilling PE is simply like drilling any other thin metal. Use a sharp HSS bit. To hold the PE for drilling, you might try taping it with double sided tape to a flat piece of wood.
I have a 1/4" end of the tip of a sharp hand sewing needle mounted in a pin vise that I use as a scribe. For drilling in thin metal, I would find exactly where I wanted the hole to be, place the tip of the needle there, and then tap the pin vise very gently with a light plastic mallet or similar. The resulting divot in the metal would help the drill bit not to wander as the drilling started.
PHOTOBUCKET SUCKS |
