| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
09-07-2005, 11:13 AM | #16 | |
Forunn Daberator
Re: What is the difference between HP and Torque
Um yeah, thats completely wrong.
09-07-2005, 11:27 AM | #17 | |
AF -Advisor
http://www.geocities.com/MotorCity/7177/torquehp.html
There is also a discussion in the Street/Track Racing Section under Honda about the same thing.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR |
09-10-2005, 12:41 PM | #18 | |
A horsepower is a unit of power. Torque is torque. Power is a function of torque and angular velocity. With the proper gearing, acceleration and top speed depend on power.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable. |
09-10-2005, 09:59 PM | #19 | ||
read all the replys to this ? .. all say torque has somthing to do with acceleration, or your gear ratio. ok to any results out of gear ratio is for the real wheels to turn or the front what ever ok torque , sure it is A measure of force but the object has to move to get any amout of force. so forget it guys nothing you will say will change my theory of how you get deffinition. of what torque is . it is!!!!! the amout of horse power that is applied to the rear tires and to the pavement or vica versa if drive a front wheel drive . the guy dont want to no how u measure it but what is it . it is in all your replys but not in the right fase.
FAST |
09-11-2005, 02:12 AM | #20 | |
Professional Ninja Killer
Sorry, Webster disagrees.
Torque
Dragging people kicking and screaming into the enlightenment. |
09-11-2005, 03:46 AM | #21 | |
Master Connector
I think someone is smoking something they shouldn't
09-11-2005, 01:51 PM | #22 | |||
Re: Re: What is the difference between HP and Torque
Horsepower vs Torque makes as much sense as Watts vs Torque, Power vs Pound-Feet, etc. Quote:
To convert torque to power both time and distance are needed. Hence, RPM which has both a distance and time component. It is this reason that torque by itself does not give any indication of an engine’s performance. At minimum torque and engine speed are needed. As well, torque at the engine means little as it can be multiplied nearly indefinitely to the wheels. Of course the trade off of gearing is rotational speed or angular velocity, but the one constant factor is power.
|_|_|_|_|_|_|_|_|_| |
10-22-2005, 05:13 PM | #23 | |
sracing has it right. i think that it's just that some of you can't visualize what he's trying to tell you. horsepower & torque are two different viewpoints of the same equation regardless of how some of you seem to believe things are.... 1 horsepower is defined as the amount of energy needed to lift 550 pounds of weight a distance of 1 foot in 1 second. simply put, horsepower is the application of torque, over time, whereas torque itself is the amount of force generated by the twisting motion of an object, measured at a given distance (i.e. inches, feet, millimeters, what have you) from the center of the axis at a right angle. torque can be measured as either a static measurement (holding a given weight up) or dynamically as a peak potential quantity (i.e. max breakaway torque achievable @ a given rpm). it's really very concept to understand.
02-18-2006, 12:20 PM | #24 | |
JESUS DON'T USE CAPS.
Please don't use all capital letters. It looks much better when you type normally. And yes, that's why diesels tout potentially less hp than a big EFI counterpart, but puts out a load more torque: You might not get speed out of it, but you can pull more. My inline 6 only has 145 hp (as opposed to 205 of my dad's 302 of the same model year) but it has the same torque, so we can haul the same load, he'll just do it with a bit more speed and ease.
1994 F-150 XLT 4x4 ext. cab 5.0 R.I.P. '96 300, may those dirty mechanics burn in hell. |
02-18-2006, 12:26 PM | #25 | |
Forunn Daberator
You get onto someone for using caps in a four month old thread? Both are equally annoying.
02-18-2006, 12:27 PM | #26 | |
I was searching threads and saw this. Neither here nor there, and I did put relative info in the thread.
02-18-2006, 12:29 PM | #27 | |
Forunn Daberator
Just dont confuse relative and useful.
02-19-2006, 06:03 PM | #28 | |
Torque is defined as the sum of force vectors around an axis (of rotation). Basicly that means than on an axle torque is the force that will try to rotate the axle. We can have torque and no rotation and torque with rotation.
Torque can be used to do work. Work is defined as force multiplied with distance. Horsepower is one unit of power, according to international standard power should be measured in watt. Horsepower was used as a measurement since some of the earliest steam engines replaced horses to power water pumps used in mining. One horsepower was the mean power produced by an average horse. Power can be defined in many different ways depending on the situation, if we talk about engines the most common definition is power equals work per time unit. What makes a car perform is the engine power, not torque. For example to make a car accelerate you need the power, P: P = Fv = mav m = mass a = acceleration v = velocity Power is also what makes the top speed of a car. In order to drive at a certain speed the drag (aerodynamic and rolling friction) must be overcome. With a drag, F, the power, P, to drive at a certain velocity, v, is: P = Fv In order to offer a high performance a high power output at a certain rpm isn't enough. Instead the maximum output in a certain range is required, for example 6000-9000 rpm. What range is required depends on the application, a four speed gearbox will for example require a better range than a six speed gearbox. So if it's power that do the all important stuff, what does the torque do. Well, torque is what makes your clutch slip, it's also what can overload the gearbox. Basicly torque itself has no function, but it is required to develope the power. Sometimes "torque" is incorrectly used to decsribe the low speed performance of an engine. Even though it's incorrect use of "torque", an engine that is powerful already at low speeds tend to have a good "range". |
02-20-2006, 01:32 AM | #29 | |
and with that description... this thread is closed. Too old for my tastes
