Go Back   Automotive Forums .com Car Chat > Chevrolet > Malibu
Old 08-14-2016, 07:42 PM   #1
gpmodelj70
99 malibu...temp gauge & AC
Hello,
I have an issue which has stumped me...sitting at idle, the AC and temperature gauge works properly...if I pull out onto the road, then at ~10 mph and up the temp gauge goes to zero and the ac clutch disengages...any ideas?..this happens together every time.
gpmodelj70 is offline   Reply With Quote
Old 08-14-2016, 09:08 PM   #2
brcidd
brcidd's Avatar
Re: 99 malibu...temp gauge & AC
Is yours a manual a/c system (no digital readout for temp control) if so read on:
Does the green a/c indicator light go off as well-- if so wiggle the fan speed switch- it acts as the "Master" on-off switch for a/c- and the contacts get hardened grease on them that disables the a/c command-- seen a bunch of them. Fix is to remove blower switch and polish the contact surface area with a pencil eraser....
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 08-14-2016, 09:13 PM   #3
gpmodelj70
the indicator light does not go off...is it possible that the ECM is losing its signal for engine temperature and shutting off the AC on purpose?
Old 10-02-2016, 12:23 PM   #4
Kristi'sChevy111
Our 08 Mailbu is doing sort of the same thing. The temp gauge does not move at all & the a/c doesn't work at all. We disconnected the battery and everything works for a couple days then goes inop again. We changed out the Engine Coolant Temperature Sensor but that didn't help. We don't want to keep throwing parts at the car so if you find a fix for it please let me know.
Kristi
Kristi'sChevy111 is offline   Reply With Quote
Old 10-02-2016, 04:24 PM   #5
Stealthee
Your worst nightmare
Stealthee's Avatar
If the ECU does not see voltage from the coolant temperature sensor it will disengage the AC clutch. It is a failsafe. It basically sees no voltage as an overheat. When it overheats it will disengage the AC clutch as well.
Stealthee is offline   Reply With Quote
Old 10-03-2016, 08:26 AM   #6
Blue Bowtie
Registered Offender
Blue Bowtie's Avatar
In summary, the CTS itself has been replaced but the problem remains. This may be due to open circuits in the wire harness, including connectors, splices within the harness, and wires themselves. The fact that it is intermittent will make it more difficult to locate. A factory service manual with schematics will be very useful in determining all the connectors and areas involved in the CTS circuit.
Old 05-09-2017, 08:13 AM   #7
gpmodelj70
I still have not resolved this issue...I unplugged the ECT connector and used a 400 ohm resistor...gauge still drops to "cold" whenever the car is rolling...to be sure someone has resolved this issue on their car!?
Old 05-09-2017, 08:14 AM   #8
gpmodelj70
Does anyone have a factory service manual with wiring schematics that can send me a scan?
Old 07-17-2017, 11:10 AM   #9
03GMCSonoma
I have an 07 Malibu with 2.2l engine doing the same. Intermittant temp gauge reading cold, and A/c not working when this happens. Looking for answers. No check engine light coming on either.
03GMCSonoma is offline   Reply With Quote
Old 07-17-2017, 01:37 PM   #10
gpmodelj70
Did that...no change...still same issue...swapped out the dash control with a known good one...no help
Old 07-17-2017, 01:41 PM   #11
gpmodelj70
Angry Re: 99 malibu...temp gauge & AC
Connected scanner to monitor engine coolant temperature while car is in motion...computer disconnects from the scanner at the same time the temperature gauge drops to zero and AC clutch disengages
Bookmarks
Search this Thread:
