Old 02-12-2010, 11:07 AM   #1
CifeNet
CifeNet's Avatar
A good transparent yellow for large areas?
Hi,
I have Tamiya's transparent yellow acrylic paint for painting turn signal blinkers and such. I have sprayed several times on a larger scale, but the result wasn't as good as I expected. Maybe my technique needs to be improved, but the paint would sit on edges and you get a different shades.
Probably I will go with lacquer based. Can you recommend something based on your experience?
I am interested in painting the head light covers and side/back windows.
Thanks~
-- CifeNet
CifeNet is offline   Reply With Quote
Old 02-12-2010, 02:19 PM   #2
stevenoble
stevenoble's Avatar
Re: A good transparent yellow for large areas?
The best is Alclad lacquer transparent yellow. I used their smoke finish to tint the screen on my Tamiya Suzuki Hayabusa and it gave an excellent finish with no darker areas or anything. Dries in minutes as well.
Steve Noble
stevenoble is offline   Reply With Quote
Old 02-12-2010, 07:45 PM   #3
CifeNet
CifeNet's Avatar
Excellent!! Will give Alclad a try! I will find who is carrying the paint.
Thanks!
-- CifeNet
Old 02-12-2010, 08:53 PM   #4
bri g
not sure if they are available in your area but I've had good luck with Gunze's mr hobby clear yellow laquer spray can.
bri g is offline   Reply With Quote
Old 02-13-2010, 06:32 AM   #5
scale auto style
scale auto style's Avatar
Yes alclad is the best for this job and one good thing with this product is: if it's a bit to dark for you you can use the transparant medium. adding a bit of this will gave you more transparancy. in fact you will be able to do a grade shade.
if you don't find it in your area I have a couple of bottle left. contact me direct to see what I can do for you
yours
sebastien Lebeau
www.scale-auto-style.com
www.scale24-25.com
scale auto style is offline   Reply With Quote
