Go Back   Automotive Forums .com Car Chat > Ford > Escort
Old 09-01-2013, 12:53 PM   #1
calla1231
Send a message via AIM to calla1231 Send a message via Yahoo to calla1231
97 excort 190,000 miles
When the car has been running awhile the coolant reservior and radiator make a boiling sound. It really only does it when it's been at idle for a bit. Radiator is full. Fan doesn't seem to come on after it has been running awhile but does when you turn on air. At what temp should it come on? The temp gauge never goes above the middle point so it stays in normal range, even when the tank are radiator are gurgling.
calla1231 is offline   Reply With Quote
Old 09-01-2013, 01:29 PM   #2
The Ruth
The Ruth's Avatar
Re: 97 excort 190,000 miles
Usually that exact combination of symptoms points to a blown head gasket. The only reason for there to be gurgling involved without overheating would be if exhaust was mixing in. You can get kits to test if there are exhaust gasses mixing in.
'14 Ford Escape
'13 Ford Focus
'88 Ford Mustang
www.HelpUFindStuff.com
The Ruth is offline   Reply With Quote
Old 09-01-2013, 01:33 PM   #3
calla1231
I guess the gasket could be bad but it's only 2 years old. This isn't a constant problem. It only does it every once in awhile.
