| Latest | 0 Rplys |
Classic Cars Do you just love the classics? |
10-29-2008, 01:55 PM | #61 | |||
Re: Wrong master cylinder - should I worry?
I do have my old MC, in fact we took it apart, cleaned it up well, and put it in just to see what would happen, and it reacted the same with the new and the old MC's). The booster was sent back to the place where we got the new one from (West Coast Cougar Classics) for the deposit. I suppose I could call him and see if he still has it but I doubt it. Thank you so very much for all of your help on this Bob. Your input has been what has kept me going and not giving up.
Blessed are the cracked ones, for they are the ones that let in the light. Quote:
10-29-2008, 02:56 PM | #62 | |
You can do the rear shoes if you want, just make sure they are adjusted and (the long shoe goes to the rear) about equal to each other. This will give you a better pedal. That's why the pedal will come up with a couple of pumps, which has nothing to do with air in the system. It will help overall.
Install the original proportioning valve and take out the adjustable one, just to simplify the equation. For laughs, see what the depth of the recess (for the rod) is in the old one, measure it and write it down for now. You can compare it later when you get up the nerve to take the "new" one out again. Maybe your booster manufacturer can double check to see that you have the right part for the disc brake application. I doubt he'd have yours around still. I don't mind helping you out, the problem is intriguing. I'd like to see you get it solved eventually. I've played with old Cougars (the car type), Mustangs, Fairlanes and Falcons quite a bit and never ran into something like you got there. We'll get to the bottom of this yet! Bob |
11-02-2008, 06:00 PM | #63 | ||
hahaha... just an FYI - took the cougar out for a quick ride on halloween - the push rod is out too far. The brakes started to seize pretty bad by the time we limped it back into the driveway. Guess what I'm going to be doing tonight! hahahahahahahahaha.... Oh well, at least we know where "too far" is!
Interesting though, I replaced the check valve and now the pedal seems to want to grab or work well at the top end of the pedal and then fades????? Have to fix the push rod and take it out again so I can get a better idea of what it is doing now.
11-03-2008, 07:20 AM | #64 | |
Hooray, something happened! You HAD to force it to get something out of it, now you KNOW where too far is. I agree that now you have to back the rod off a tad.
You do understand what happened, the brake fluid heats up and expands, locking up the brakes due to having insufficient free play. Go with an 1/8" to start. I think you're close to a solution and it will be a totally different animal once you fine tune the rod. If you haven't done it, check the rear brake adjustment as this will help the pedal height. Bob |
11-10-2008, 06:09 PM | #65 | ||
Update on the brake saga of SATAN'S COUGAR
Ok, so I adjusted the push rod back about 1/8 inch and then proceeded to check the back brakes, just in case there might be something amiss, or contamination or whatever. Well..... Bwahahahahahaha! Here is what we found when we took off the drum. Yep - the pad is actually BROKEN. There is an extra piece that was floating around in there - hmmmm. Think this could have been an issue????? Keep in mind, we had these brakes completely apart and put in new wheel cylinders and springs etc - why we didn't get new shoes I don't know, but the old ones looked ok with pretty decent wear life on them. There was no damage to them when we had them apart the first time. Either we have some of the worst brake luck in the world, or this car is just another Christine in the making. I think with the properly adjusted push rod, the new check valve, the new booster, the PROPER MC, the leaky line fixed at the prop valve, new pads, new shoes, new calipers, new lines, new wheel cylinders and another bleed - I might just have it...... Yeah - I'm not holding my breath, but I am hopeful.
11-11-2008, 08:48 AM | #66 | |
I can't see the picture at work, but my guess is that a piece of the brake shoe lining broke off. Old shoes get brittle and often a corner breaks off from taking the drum off and on.
Slap a new set of shoes on, adjust them up (do not bleed it, quit while you're ahead!!) and go for a ride. Bob |
11-22-2008, 08:54 PM | #67 | |||
The brakes are still not right but they have "changed" through all of this. What I get now is a stiff pedal when the car is of (rock solid). A soft pedal when the car is on -which feels normal. What it does do however, is gives a good grab for the very first second when you hit the pedal, then it "fades" and you have to increase the pressure on the pedal until the brakes fully engage. If you drive for a bit without using the brake, it does the "grab first touch and fade" thing. If you continue to use the brakes, the first grab seems to go away and the brakes become progressively more difficult to get to engage. My thoughts now are leaning toward vacuum - either the booster (which is new, but could possibly be defective), or just a bad vacuum somewhere. Any thoughts? I know it can be really tough when you can't actually feel the pedal but I am hoping from the description you might have an idea. Thanks again Bob.
11-23-2008, 09:04 PM | #68 | ||
Nothing scares me anymore
In my experience, a few things can cause this. If the vacuum line going to the booster is under-sized, or if there is an under-sized fitting, a kink in the line or any other kind of partial obstruction or leak, your vacuum booster will 'fade away' exactly as you describe. Also the vacuum source needs to be the manifold vacuum (the one that sucks most at idle) not the ported (distributor) vacuum. If there is no obvious obstruction, install a vacuum gauge on the vacuum line for the brakes. Tee it in if you have to, and measure the vacuum strength that the brakes are getting. It should be at least 18 inches of vacuum at idle. It will drop as you step on the gas, that's normal...... any less vacuum can cause a problem like you describe. Poor vacuum can be a result of improper valve timing, leaking intake valves or a radical aftermarket camshaft. If all this checks out then it may be a bad booster. |
11-24-2008, 08:38 AM | #69 | |||
I am hoping it is a hose because I am pretty sure the valve timing is ok, I'm not getting any ticking or knocking and the engine is running smooth and strong.
11-24-2008, 08:40 AM | #70 | |
The acid test for a bad booster is: With the car off, pump the pedal until you exhaust all the vacuum in the booster, it should be very hard at that time. With your foot on the brake pedal, start the car. The pedal should drop very noticeably. That means the booster is probably good or has no gross leak.
To really rule out the booster, unplug the vacuum line and plug it, you really have no brake booster. Now go for a ride. If the hydraulics are really good, it will stop but you have to use more force. It should be consistent though. Aside from that, go with what te MagicRat suggests. Bob |
11-25-2008, 09:44 PM | #71 | |
well i been reading with you guys, and was wondering if you made any headway?
1965 ss conver chevelle "red 1964 ss impala "red" 1964 bisq. gold 4 doors current 1968 chevelle " all apart at the moment" |
11-26-2008, 04:46 PM | #72 | |||
12-10-2008, 09:10 AM | #73 | ||
Just a quick update. I plugged off the headlight vacuum hose and tried it again. The brakes are better. Still not quite right but I think they are good enough to pass inspection. I plan on tweeking it more and putting on the vacuum tester, just haven't been motivated as of late. I am just elated that I was able to get it out, drive it around and feel like I could actually feel like the brakes are safe.
Thanks to everyone for their help. A special thanks Bob and Magic Rat for you unending confidence and fantastic help/suggestions. I owe you big time!
01-17-2009, 06:24 PM | #74 | |
Couple Of tips for you:
Hook up a T with the vacuum gauge going inside and watch it when you hit the brakes, if it gets less that 15 or so you may have a blockage or booster may be bad. Just beacause a part is new or rebuilt doesnt mean its good. I have had bad luck with rebuilt master cyls, Buy a New one. Rebuilt boosters are bad too sometimes. Cheap or glazed brake pads will cause or magnify your problem, Use the Hawk street compound pads from summit, pep boys. They're great. And the most likely - Check if your front calipers are reversed - Left will fit on the right side and vice-versa, but you will never be able to bleed correctly. Look at the bleeder valves, should be at the uppermost point on the caliper cylinder. Also brakes must be bled with vehicle level. Good luck! |
01-19-2009, 10:05 AM | #75 | |||
