Thread Tools | Search this Thread |
Did I fry my ECU !!?? Help please.
'01 3.0i auto;
This morning I was trying ton confioirm Peak code 7b (Thermostat map control) which as I understand, is related too the heating element of the main Thermostat (2 prong connector on top, just behind the top of the fan blade). To check that I was getting power to the plug/heater element, I connected my volt meter to the 2 prongs in the plug/harness side and turned the key on while watching. The meter bleeped a bit but nothing, so I dicided to start the engine and see if that would bring the power up. No start. It turns over but wouldn't start. Replugged the connetor - same. Checked all related fuses - OK. Disconnected the battery for an hour - same. Any help on something like this?? THANKS IN ADVANCE!! Worried ![]() |
Re: Did I fry my ECU !!?? Help please.
you need a ecu tools and you can find some good ones in xcardiag.com
i had buy some from it and they are cheap and good |
![]() Join Date: Apr 2005
I broke that sensor off in the housing and its been dangling in its clip for 7 years.
Check f or other plugs you 4got to plug in. |
Bookmarks |
