Go Back   Automotive Forums .com Car Chat > Toyota > Highlander/Highlander Hybrid/Kluger
Old 01-22-2005, 12:49 PM   #1
Ed 50
Question 2004 Highlander transponder key programming
Does anyone know how to program a transponder key for a 2004 toyota highlander? I purchased two blanks from e-bay. One is for a transponder bypass for an auto start, so it doesn't need to be cut. I've tried the "turn key on/off 5 times, open and close the door 6 times, remove good key and install key to be programmed. Wiated for the security light to quit flashing, but it never. HELP
Ed 50 is offline   Reply With Quote
Old 06-01-2005, 09:30 AM   #2
CloneNum3
Make sure you are using the Primary Key, not the Valet key to program the new transponder.
CloneNum3 is offline   Reply With Quote
Old 12-31-2011, 07:23 PM   #3
sasdjt
Re: 2004 Highlander transponder key programming
Here are instructions that apparently work (from http://www.keylessfobprogramming.com...try-fob-remote)
How to Program a 2004 Toyota Highlander Keyless Entry Fob Remote
*Warning* If you have replaced the battery in your current keyless entry remote and the remote is still not working, this is a good indication that the keyless entry remote will need to be replaced.
Get in the drivers side of the vehicle, make sure all the doors are closed except the drivers side door and all the door locks are unlocked.
Insert the key into the ignition without turning and remove it quickly
Close the drivers side door, then open it.
Insert the key into the ignition without turning it and remove it quickly.
Insert key into the ignition (do not remove, do not turn).
Close the drivers side door.
Turn key to “On”, then to “Off”
Remove the key
Vehicle locks should lock and then unlock to signify programming mode. If not, repeat above steps.
Press and hold “Lock” and “Unlock” on the keyless entry remote simultaneously for 2 seconds.
Let go of the buttons and quickly press the “Lock” button (by itself) on the keyless entry remote and hold it for 2 seconds.
Doors should lock and unlock to signify successful programming
Repeat 2 previous steps to program additional remotes
Open the drivers side door to exit programming mode.
sasdjt is offline   Reply With Quote
