| Latest | 0 Rplys |
12-26-2003, 04:31 PM | #31 | ||
Re: Mustang vs. Camaro
i made sure i worked on suspension, brakes, and weight reduction before reel performance. and w/ as much power as u said u had u probaly coulda beat me no prob. im probaly only pushin 230hp. this is my suspension setup. JIC FLTA2 Adj Coilovers Cusco Rear & Front Strut Bars Cusco Sway Bars Energy Suspension Bushings Cusco Lower Arm Bar Perrin Front & Rear Endlinks Weight Reduction Mods: new JIC Full Titanium Exhaust Removed Spare Tire and trunk carpeting(that may come back 2 haunt me) 2 Bride Racing Seats & Removed Back Seats Im in the process of removing door panels and ripping out my carpet. for power im saving up for an IHI VF-30 Turbocharger w/ a Turbo XS Front-Mount Intercooler. Im also saving up for an Exedy Clutch & Flywheel. |
12-26-2003, 04:34 PM | #32 | |
and as for nitrous my top 3 are NX, NOS, and Venom. but Venom is too expensive.
12-27-2003, 02:24 AM | #33 | |
Nice set up you have there.
I run the Zex kit, very safe. I have an RPM window switch that activates it, and cuts it off. I also run a electronic shut off valve. just incase.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
12-27-2003, 03:20 PM | #34 | |
Pusstangs
12-27-2003, 03:29 PM | #35 | |
Pusstangs. Never heard that one.
12-28-2003, 01:27 PM | #36 | |
i agree with high-flow about the timing adjustment..im going to purchase a 150 shot from NOS in a couple of weeks and im going to return my timing to the original state.
95 GTS...9mm FRPP spark plug wires, BONE STOCK |
12-29-2003, 11:31 PM | #37 | |
Here is also a suggestion for you guys who are planning on running nitrous. I was very happy with the performance increase after I had my timing advanced, so I was reluctant to have to pull the timing out when I put the nitrous on. Basically i was giving up my n/a performance, which I use like 95% of the time, just so that I could run a performance booster I was going to use like 5% of the time.
You can buy an Accel 300+ ignition box. http://www.jegs.com/cgi-bin/ncommerc...35&prmenbr=361 Then get this digital controller unit, and it'll allow you to set up a timing pull for when the nitrous is in use. It has a signal wire that connects to the nitrous solenoid power circuit and then pulls timing whenever the nitrous is being sprayed... http://www.jegs.com/cgi-bin/ncommerc...29&prmenbr=361 Just a thought, so that you can keep the n/a performance and still use nitrous. BTW, if you are an MSD fan, I think they also make a digital box, called the MSD 6AL or something like that, which allows for a similar setup. Might be worth checkin in to... |
12-30-2003, 05:55 AM | #38 | |
Well Im running msd 6AL now so I'll look into that. My current set up might allow me to do that but I'll have to contact msd to find out. Thanks Hot Red Z28
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator (If it doesn't scare the Hell out of you it isn't fast enough) |
12-30-2003, 06:23 AM | #39 | |
Stanger
If you already have an MSD, then you can get a retard module that plugs right into the MSD. You will then have full control of timing advance and retard through a control knob from inside the car.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
12-30-2003, 05:55 PM | #40 | |
Ok that sounds pretty good. But let me ask you this highflow the system I want is a zex system.Is it possible to set this system up so that the timming is pulled automatically at WOT before the nitrous gets injected?
12-30-2003, 05:59 PM | #41 | |
i know that NOS sells a kit with that in mind
12-30-2003, 06:15 PM | #42 | ||
Stanger
12-31-2003, 12:13 AM | #43 | |
The system should just run off the hot side of the selonoid, but like HiFlow said, you can run a window as well.
12-31-2003, 01:08 PM | #44 | |
Camaro All The Way
12-31-2003, 02:19 PM | #45 | |
Stanger
Great, another noob with nothing intelligent to say.
