| Latest | 0 Rplys |
03-09-2006, 07:44 PM | #16 | |
Re: 94 RAM 1500 Cruise
I wouldn't do that you could possibly fry something more.
03-09-2006, 07:44 PM | #17 | |
03-10-2006, 02:35 AM | #18 | |
Don't jerry rig your cruise. Think about it...Your cruising at around 60mph..
2007 Certified DaimlerChrysler Service Technician... True blue GM at heart. |
03-10-2006, 06:31 AM | #19 | |
Well, the thought wasn't to actually use it on a regular basis that way, just for test purposes...but i get the point.
I was installing some "foot" lighting yesterday on/off with the dome light--(a nice detail btw) and noticed a yellow molex plug that was fastened to the metal "U" shaped crossbar right above the hood release. I unplugged it, replugged it and i do know it's not the horn...but it does snake up the column. What does that connector, connect to? Airbag maybe or something else? The wires were dark green & black. Thinking again...put a test meter on it. -- Ray -- |
03-10-2006, 12:37 PM | #20 | |
That was the airbag wires. Avoid unplugging them with the battery connected, and DON'T check it with a meter..
03-10-2006, 12:50 PM | #21 | |
Well...
I unplugged it (yesterday) and re-plugged it...nothing happened. Do I need to get something checked now or is it fine? - Ray - |
03-11-2006, 08:24 PM | #22 | |
you should be fine. download the manual and you will have better luck knowing whats what
04-05-2006, 11:19 AM | #23 | |
Looking through the manual, I notice the wires listed are two vac controls, a brake control, and a ground.
Can I somehow put some other switches on this for testing purposes since its a possiblility that it's the Clock Spring that's bad inside the column? |
04-07-2006, 07:32 AM | #24 | |
ALSO...i just checked JC Whitney's site (i get regular emails).
They have an aftermarket Cruise unit....could I possibly wire that using any of the existing controls or servo or something? I just wondered too, if i could put a meter on the wires under the dash that go to the cruise buttons and see if maybe that's the problem or if it's up in the ClockSpring... just kinda dumbfounded...thats all Let me know...i appreciate all your help! |
05-29-2006, 10:19 PM | #25 | |
Check the main wiring harness on the driver's side of the engine, where it turns down towards the tranny. Look for melted/shorted wires.
