Go Back   Automotive Forums .com Car Chat > Ford > Escort
Old 07-15-2014, 01:56 PM   #1
thomasedwin
thomasedwin's Avatar
How to tighten crankshaft pulley bolt
On a 96 ford escort 1.9 liter with automatic trans, after replacing the timing belt, how do you tighten the crankshaft pulley bolt when I only have hand tools? It needs 90 or 95 foot pounds but you can't tighten it because the crankshaft just turns around and I can't find a way to lock the crankshaft without causing possible damage to the pulley or putting stress on the new timing belt. I thought of taking out the starter motor and somehow blocking the flywheel but I don't want to cause any damage to the flywheel teeth. Is there a special tool or method to do this???????
thomasedwin is offline   Reply With Quote
Old 07-15-2014, 04:39 PM   #2
aleekat
Re: How to tighten crankshaft pulley bolt
I have been using this method for years. "The Rope Trick". It's quicker and easier than the "tool", and the basic steps are simple:
 (loosen/tighten)
1 - Pull plugs and rotate crank to #1 0° TDC Compression
2 - Rotate crank about 90° past TDC.
3 - Stuff about 3 feet of clothesline into # 1 plug hole, leaving 6" outside (feeding the rope in thru a short length of heater hose makes the job even quicker).
4 - Rotate the crank backwards until the packed rope stops further rotation.
5 - Use socket, breaker bar, and pipe extension to loosen pulley bolt.
6 - Tighten bolt the same way, but start with crank about 90° before #1 TDC Comp.
7 - Once tightened to spec, back the crank up a little and remove clothesline.
Post back, that's what makes Forums Work.
aleekat is offline   Reply With Quote
Old 07-16-2014, 04:06 AM   #3
thomasedwin
I would be afraid I couldn't get all that stuff out of the cylinder well after I tightened the bolt, think if that stuff got stuck in there, you would have to pull the head off to fix it.
Old 07-16-2014, 05:21 AM   #4
ashleydaniel2691
Oh that's really interesting! Whether is that possible to tighten crank pulley without dismantling the engine?
ashleydaniel2691 is offline   Reply With Quote
Old 07-16-2014, 07:47 AM   #5
brcidd
brcidd's Avatar
Most ask the question- "how to loosen the cramk pulley" you must have used an impact wrench- so that is how I tighten...
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
Old 07-16-2014, 09:03 AM   #6
aleekat
Been doing it for years. Dodges, Volvos, Mazdas etc. Everything from a big block V8 to little 1.8 2.0 4 bangers. Only issues I have ever heard of a guy forgot to pull the rope back out and cranked it over. Just make sure you are on TDC on the compression stroke so the valves are closed.
Old 07-20-2014, 06:57 PM   #7
12Ounce
I use to use the "rope trick" and it worked well for me. But I have recently tried the method where an old serpentine belt is back-folded around the crank pulley ... works pretty well, much better than I expected. Much quicker than the rope trick.
12Ounce is offline   Reply With Quote
Old 07-20-2014, 09:29 PM   #8
aleekat
Always willing to try something new. Care to elaborate?
Old 07-30-2014, 12:39 PM   #9
12Ounce
Let me find a link if I can ...
Old 07-30-2014, 12:49 PM   #10
12Ounce
Look at the photo in posting #3:
http://forums.swedespeed.com/showthr...emoval-problem
