Go Back   Automotive Forums .com Car Chat > Jaguar > XJ6| XJ8| XJ12 | XJR
XJ6| XJ8| XJ12 | XJR Classic and Current XJ Models, including the R series.
Old 09-04-2007, 09:49 PM   #1
sam666
xj6
Hi I Am Planning To Buy An Xj6 It Is A 1987 But Car Will Not Start The Guy Who Own This Car Think The Fuel Pump Is Not Working .can You Tell Me Were Is The Fuel Pump Is It Is Not Getting Any Gas.thank.
sam666 is offline   Reply With Quote
Old 07-26-2008, 12:13 AM   #2
djagman
Re: xj6
do not automaticly think it is the pump.they are very robust.try checking powre to it first.you dont have to dissasemble the car just go on the passenger side and right by the side of the dash is a small black box.remove the cover and check for power on both!!!!!sides.if yes then check pump if no check fuses and the red diode pack at firewall.this vehicle does have a inherant problem with the ignition switch burning up so i would check the basics and go to the switch!!!
djagman is offline   Reply With Quote
Old 07-26-2008, 12:37 AM   #3
'97ventureowner
'97ventureowner's Avatar
Re: xj6
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines:
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
'97ventureowner is offline   Reply With Quote
