| Latest | 0 Rplys |
Car Comparisons Compare any cars and find out what every body else thinks. Just refrain from making stupid comparos like Viper vs. Geo Metro :) |
01-12-2005, 04:28 PM | #61 | |
Re: The battle of supercars, how far has America come?
Performance*
0 - 60 mph [secs] 3.3 0 - 100 mph [secs] 7.4 1/4 mile [secs at mph] 11.2 at 131.2 Top Speed [mph] 200 Lateral acceleration [g] 0.99 Fuel Economy [City/Hwy in mpg] 14 / 21 Hmm, a list of specs from the site where accleration is the same as MT found, but not skidpad, top speed, or even mpg. More evidence of the vast conspiracy...lol |
01-12-2005, 05:26 PM | #62 | |
I'm suprised to see nobody took vehicle aerodynamics into consideration. Lets not forget that drag is proportional to the cd, frontal area, and the square of speed. A car going 120mph will have 4 times the drag of a vehicle moving at 60mph. Another factor associated with aerodynamics is lift. Lift results from a negative pressure resulting in the varying speeds of air flowing above and below the vehicle. A good cd will only go so far until you need to compensate for the adding lift at speed. To keep a car 'glued' to the ground you need to create some downforce. Things such as adding a wing help keep the rear end on the ground. You have air dams, ground effects, smoothing of the undertrays, diffusers. These all help smoothen the flow of air producing downforce and limiting lift, but this all comes at a price (usually an increase in overall cd). So to sum it up, trying to achieve the lowest cd possible and maintain highspeed stability will help determine how much hp you will actually need to go a specific speed.
A stock C6 has a cd of .28 vs. the .34 on the Z06. So theoretically the standard C6 has less drag to fight against, but the Z06 upped the cd in order to maintain stability at higher speeds. I tell you its a cat and mouse game! Things such as weight distribution and layout also change the aeodynamic features of a vehicle. So everything needs to be accounted for when designing the best workable setup. MR, RR cars have more weight in the back giving them an advantage against FR, FM vehicles against rear end lift (which is a serious spot for lift). This only further shows the dynamic differences in different layouts. This is pretty basic, but I hope it helps anyone out. There are a ton of variables involved so this isn't what I would call concrete and sound (since I am not an engineer). So, which car will be faster? Heck I don't know? My almighty biased wisdom is telling me it will be the Z06 . |
01-12-2005, 05:39 PM | #63 | ||
Re: Re: Re: The battle of supercars, how far has America come?
01-12-2005, 06:08 PM | #64 | ||
01-12-2005, 08:59 PM | #65 | ||
There is alot of inconsistancy between magazines if in the same magazines. Some time they'll same one number and another time they say something else. It probley depends on how much the company give them in advertising. |
01-12-2005, 09:15 PM | #66 | |
And for drag on a car in MT they tested the Enzo, Ford GT, and Carrera GT and at 200Mph the Enzo had 837 lbs of drag. The Ford GT had 874 lbs, and the Carrera GT had 889 lbs of drag. Just some info.
01-13-2005, 12:17 AM | #67 | ||
01-13-2005, 01:14 AM | #68 | ||
303whp stock internal KA-T 94 Acura NSX Best E.T. 13.559 Best Trap speed 107.62 mph |
01-13-2005, 10:21 AM | #69 | |
Razor Sharp Twit
jut so you know for future use....
ash fault=asphalt |
01-13-2005, 10:58 AM | #70 | |
^lol ya I had a hard time trying to find how to spell that and never got it right. Darn schools.:lol
01-13-2005, 11:02 AM | #71 | |
Razor Sharp Twit
...don't worry about it.....
i mean, i got a typo in that post too...... just thought it'd be good to 'correct' you before somone picks on it vindictively. |
01-13-2005, 11:34 AM | #72 | ||
01-13-2005, 12:06 PM | #73 | |||
Well, first you said this:
And since when is a quarter mile a test of acceleration? It's a test of how fast you can cover a quarter mile length track, and if you have to compromise acceleration a little bit by lengthening your gears to get down the track faster, so be it. If a quarter mile run was a test of acceleration, then I guess that Supra that syr74 talked about should have started in 1st gear, since it gives better acceleration than starting in 2nd gear...wait a second, that didn't help him at all, it slowed him down because he was smoking his ass off. |
01-13-2005, 12:52 PM | #74 | |
STREET RACING GURU
i see you guys calmed down a bit
lets not get to out of hand and i thought they ran the ford gt at the fastest 11.6? i need to catch up on the super car scene
01-13-2005, 01:36 PM | #75 | ||
First gear is a shorter gear than second is in every car I know of, that is a fact. If acceleration always improves with shorter gearing then this car should be faster when launched in first. However, shorter gears don't do a damned thing to help acceleration if you are producing so much torque that you have to shift out of the gear before you even hook up in it! If you had done some drag racing instead of drag reading then you would know this. Very torquey cars like the Viper and the GT likely cannot use a shorter gear to their advantage because they are just gonna smoke the hell out of the hides instead of getting any faster. Add that into the extra shifting you will liekloy have to do so that you could get those "deeper" gears and you can see where this takes you. The Vette could make use of shorter gearing due to it's relatively high/peaky torque curve. But, to act like this would be a huge advantage for the Vette is ridiculous. To think that then you have to assume that the Viper and GT would also benefit from having lower gears than they do, and the manner in which their motors deliver that power makes that unlikely especially on street tires. And, your comment that we were "discussing top speed" further shows that you do not understand what torque is, or how it is related to acceleration and hp. Torque is an engines ability to work, hp is an engines ability to do work over time. It might be easier to think of it like this..... imagine torque is how hard you punch, and hp is how many times you can throw a punch in an hour. That is essentially how hp and tq are related. That said, I have never changed my story. It has remained the same since I began posting in this thread. Likely, you thinking I changed my story has more to dso with the fact that you simply do not understand what I am saying than anything else. The fact that you did not know that top speed in a gear can be calculated by using tire daimeter, axle ratio, and the gear ratio is kind of surprising. It's nothing more than basic Algebra. Half the guys on the forum can do the same thing I did. I also don't have time to argue with you over topics you don't yet understand as classes started for me today. If you want to choose to continue to be ignorant and call everyone who proves you wrong or embarasses you because you are ignorant on a particular issue a liar then you are likely to have a good long life picking up cans on the side of the road. If you decide to open you mouth less, and your ears a lot more, you just might learn something. And actually, as for the "deeper gearing" argument we were both wrong. I was wrong about what top speed was in each gear because Chevy changed the gearing for the Z06 which has not been in any press realeases that I have seen. You were wrong about the Z06 having significantly deeper gears, because again Chevy is not using the same tranny gear-ratios in the Z06 that they used in the standard C6. Or, at least it would appear they are not doing so because I stumbled accross a press release that noted a much higher first gear ratio than the standard C6 has. That said, by the time you factor this in with the axle ratio the drive-ratio in first gear works out to be about what the Viper's is. Did you pull the Z06's supposedly shorter gearing out of your ass? It's apparently not actually the case, so can we assume now that you just made this up and are full of warm, brown, squishy stuff? The differene between the above statement and mine is I brought evidence of my statement that you chose not to believe. Lets see evidence of the Z06's significantly shorter gearing there slick. Show me anything on it. But remember, we need to see transmission ratios and axle ratio as this is what determines the real gear ratio and wether or not the car has steeper gears. And now that I think of it, if lower gear ratios would absolutely make the car accelerate faster why on earth would Chevy change them out for higher ratios? Surely they would not do something to make the C6 accelerate slower would they? And, increased top speed is not the answer as this body and this motor are going to run into drag related problems up there before they seriously get hampered by gearing. Just some food for thought there. |
