Go Back   Automotive Forums .com Car Chat > Car Audio
Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music.
Old 01-29-2012, 03:26 PM   #1
Sizzlinninja
Whats wrong with my car's audio?
I have a custom sound system in my 2002 Civic, it has a Khicker Subwoofer, Alpine Amp, and Kenwood touch screen stereo. Now just today, when I turned it on, the music was extremely faint, I could barely hear it. I could also here a little bit of static and a whining noise coming from the speakers. The whining noise grew louder as my RPMs increase, and as they decreased became quieter. Every now and then the normal audio would come back on, but only for a few seconds at a time. It did this both with the radio, and when my ipod was plugged in, so I know I wasn't just losing signal or my aux. cord wasn't plugged in all the way. Whats up?
Sizzlinninja is offline   Reply With Quote
Old 01-29-2012, 06:39 PM   #2
outthere
Check your grounds on both the head unit and amp. Possibly loose.
outthere is offline   Reply With Quote
Old 01-29-2012, 08:54 PM   #3
PaulD
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Whats wrong with my car's audio?
sounds lik a loose ground or poor power connection to me as well. Is the head unit grounded to ground or to a wire in the harness ?
PaulD is offline   Reply With Quote
The Following User Says Thank You to PaulD For This Useful Post:
moon202 (07-05-2013)
Old 01-30-2012, 01:43 PM   #4
93CougarXR7SE
LunchboxBen
93CougarXR7SE's Avatar
Send a message via AIM to 93CougarXR7SE Send a message via MSN to 93CougarXR7SE Send a message via Yahoo to 93CougarXR7SE
Check all your connections. Grounds are the easiest to do wrong. If you can't get it figured out, just go down to the basics. I check each piece of equipment. You can pull out your stereo and wire it to the battery or temporarily run some speaker wire/lamp cord from the battery to the stereo for power. If that works, it's the power wires. If that doesn't fix it, you've got a bad stereo.
1998 E-150 cargo camper build
2014 Escape SE 2.0T
Lots of electronics and audio equipment I don't even need.
93CougarXR7SE is offline   Reply With Quote
Old 02-27-2012, 01:31 PM   #5
MONTECARLOLT
i can almost guarentee ,that you have a problem with a ground.
MONTECARLOLT is offline   Reply With Quote
Old 05-13-2013, 09:00 AM   #6
shahbaz
check your grounds
shahbaz is offline   Reply With Quote
Old 05-23-2013, 07:08 AM   #7
shahbaz
check grounds on both side and power wires too
Find your dream cars
Old 07-09-2013, 07:17 AM   #8
Emma Grace
The problem could be the analog or digital cables between the source component(s) and the receiver. Replace the suspect cables and try the source component again.
Emma Grace is offline   Reply With Quote
Whats wrong with the B18A swap? arch5 '88 - '91 Civic | CRX | Wagon | Shuttlee 74 01-31-2004 02:32 PM
whats wrong with uploader? mentalmickey Hot and Not 2 08-25-2002 08:35 PM
whats wrong with it? 97wvmax Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 4 04-16-2002 01:55 PM
