09-16-2011, 04:09 PM | #1 | |
still no start
just replaced fuel pump on a 95 jimmy 248550mi, 4.3 . it started right up and took ride but then it died , if shut off engine it would start fine but when in drive it looses power and dies.no pressure with fuel tester, fuses look good, relay clicks but still nothing. any advice to where to start looking . could it be electrical, computer ,thought might be cat at first but dont know where to start looking .the fuel pump is what thought was my original problem .
09-16-2011, 04:48 PM | #2 | |
Re: still no start
Was it a name brand (delco) fuel pump? Have you replaced the fuel filter?
09-16-2011, 06:16 PM | #3 | |
Re: still no start
yes an ac delco
09-16-2011, 06:45 PM | #4 | |
Advisor/Moderator
Re: still no start
Better start from scratch.... just because the pump is new, doesn't mean it's good. Or it could be there are other problems.
Key ON, engine OFF, fuel pump running, pressure must be 55psi to 61psi and must remain above 50psi for 3 to 5 minutes after the pump shuts off.
You have to know how it works, to figure out why it doesn't. |
09-17-2011, 04:04 PM | #5 | |
Re: still no start
im gona take for now that the pump is good ,as this is exactly same original symtom.. poss a bad wire some where. would it be wise to tap into power wire near pump then energize it. as to see if there is a break in wire
09-17-2011, 07:27 PM | #6 | |
Advisor/Moderator
Re: still no start
Best to apply battery voltage and ground directly to the pump module, totally bypassing the connector. The grey wire is battery feed and the black wire is ground. The original module connector was a poor design: High resistance would create heat and melt the plastic, deform the connector, and eventually lose contact completely. Most replacement fuel pump modules come with the new style connector and it needs to be soldered to the vehicle harness.
09-18-2011, 07:17 AM | #7 | |
Re: still no start
should i unplug connector then add voltage,what about purple wire or does that just go the fuel gauge.
09-18-2011, 10:03 AM | #8 | |
Re: still no start
have three wire connector .put power to gray and ground to black but nothing to purple and got no sound , do i need to connect purple to anything..
09-18-2011, 11:46 AM | #9 | |
Advisor/Moderator
Re: still no start
Purple and the orange wires are for the feul level sensor. The 3 wire connector is for the fuel tank pressure sensor.
Unplug the module connector. With battery voltage applied to the grey and ground applied to the black wire terminals in the module, the pump must run. If not, it's bad.
09-20-2011, 05:41 AM | #10 | |
Re: still no start
got pump out and it tested no good (frozen). thanks for everything k
09-20-2011, 12:07 PM | #11 | |
Advisor/Moderator
Re: still no start
Good job, thanks for posting back.
