| Latest | 0 Rplys |
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works? |
12-13-2002, 11:35 PM | #1 | |
93 sol, what to watch for
Im getting a 93 del sol and planing on swaping in a b16a now the motor will be a jdm so what will i have to look out for. Will the position of the fan effect anything or radiator. Now will i need a b16a sir2 or sir1. How much flipped around are things on a jdm. will the battery and everything have to be shifted to the other side. In a 93 delsol si is it an obd1 or none obd. I don't know how much of this applies and how much is point less retarded questions but any links or answers or anything. HELP
Got Sol? |
12-17-2002, 04:27 AM | #2 | |
I think the bays are the same considering in the states they had a b16 in a sol.as far as stuff being backwards only the wiring harness is backwards.Delsol is obdI it may have changed later to obdII but you are in thye clear with your year,so you are good there.As long as you get the motor,tranny,ecu,axles,shift linkage,and mounts you are good.If you are worried about the radiator get it as you will need it to cool the b anyway,the inlets are wider on the b's.Get a B16siRII the siR has cable clutch and obd0
