| Latest | 0 Rplys |
05-27-2005, 09:38 PM | #1 | |
"INSPECTION" light on dash came on?
My question is compunded by the fact that I am unable to find a owners manual for my 1987 325 that shows what the light is for. It came on and the indicator is "INSPECTION". Is this something to be concerned about or is it just a reminder to take the car into the shop for a pre-programmed mileage timed inspection? We bought this car used and thus no manual. Any help would be greatly appreciated!!
05-28-2005, 12:52 PM | #2 | |
Re: "INSPECTION" light on dash came on?
Take it to a garage or even better a BMW dealer and you will recieve eather an 15,000 or 60,000 mile tune up. 15k tune up should costg about 400 and around 800 for the 60k
05-28-2005, 10:56 PM | #3 | ||
Re: Re:
Again Thank you Tom |
05-31-2005, 12:16 PM | #4 | |
05-31-2005, 01:02 PM | #5 | |
BMW Inspection I
The BMW Inspection 1 Service is the smaller of the two inspection services recommended by BMW. It includes basically all of the items that assures safety and full functionality of your vehicle. Other makes and models can also utilize this maintenance program to ensure a pleasant drive and ownership (But make sure you mechanic says it is OK first). Inspection 1 could cost in the range of $200+ to $300+ depending on who you go to and also if you have any repairs. (Repair cost are not included in the inspection cost) So be prepared to spend more!. If your mechanical skills are high, just DO-It-Yourself! The items that are generally checked are listed below. Undercarriage Change engine oil and filter oil while engine is at normal operation temperature. Check transmission for leaks. Check rear axle for leaks. Visually check fuel tank, lines, and connections for leaks. Check condition, position, and mounting of exhaust system. Examine for leaks. Check power steering system for leaks. Check overall thickness of front and rear disc brake pads. Examine brake disc surfaces. Clean brake pad contact points in calipers. Grease wheel center hubs. Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc. Check front control arm bushing for wear. Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning. Check for free movement of the parking brake cables. Adjust parking brake if necessary. Check all tire pressures (including spare). Correct if necessary. Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required. Engine Compartment Read out diagnostic system Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary. Check level of brake and clutch fluid in reservoir; add fluid if required. Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary. Check air conditioner for operation. Reset Service Indicator. Body/Electrical Equipment Check battery electrolyte level and add distilled water if required. Perform batter load test. Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights. Check instrument panel and dashboard illumination. Check all warning/indicator lights, check control. Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch. Check wiper and washer system(s); wiper blades, washer jet positions. Check condition and function of safety belts. Oil hood, trunk/tailgate, and door hinges. Grease hood, trunk/tailgate and door latches. Check operation of all latches. Check central locking/double lock. Replace microfilter or Acc. Cabin Filter. Check heater/air conditioner blower, rear window defogger. Check rear view mirrors Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories. Final Inspection Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission Inspection II The Inspection 2 Service is the larger of the two Inspection Services and basically includes all of the items performed on the Inspection I Service along with some extras like differential oil change; fuel filter and air filter replacements; Replacement of spark plugs. Inspection 2 generally runs around $400+ to $500+. Below are the items that are normally performed. Undercarriage Change engine oil and filter oil while engine is at normal operation temperature. Check transmission for leaks. Check rear axle for leaks. Visually check fuel tank, lines, and connections for leaks. Check condition, position, and mounting of exhaust system. Examine for leaks. Check power steering system for leaks. Check overall thickness of front and rear disc brake pads. Examine brake disc surfaces. Clean brake pad contact points in calipers. Grease wheel center hubs. Check steering for absence of play, condition of suspension track rods, front axle joints, steering linkage, and joint disc. Check front control arm bushing for wear. Check brake and clutch system connectors and lines for leaks, damage, and incorrect positioning. Check for free movement of the parking brake cables. Adjust parking brake if necessary. Check all tire pressures (including spare). Correct if necessary. Check condition of tires (outer surfaces (left/right)), tread wear and pattern; In case of uneven tread wear readjust wheel alignment if required. Check thickness of parking brake linings. Half-shafts; check for leaks at flexible boots. Inspect entire body according to terms of rust prevention limited warranty. Engine Compartment Read out diagnostic system Check engine cooling system/heater hose connections for leaks. Check coolant level and antifreeze protection level; add coolant if necessary. Check level of brake and clutch fluid in reservoir; add fluid if required. Check windshield washer fluid level and antifreeze protection. Fill up and/or correct if necessary. Check air conditioner for operation. Reset Service Indicator. Replace spark plugs. Replace intake air cleaner element. Body/Electrical Equipment Check battery electrolyte level and add distilled water if required. Perform batter load test. Check lighting system, i.e. headlights, foglights, parking, backup, license plate, interior (including map reading lights), glove box, flashlight, illuminated makeup mirrors, luggage compartment lights. Check instrument panel and dashboard illumination. Check all warning/indicator lights, check control. Check turn signals, hazard warning flashers, brake lights, horns, headlight dimmer/flasher switch. Check wiper and washer system(s); wiper blades, washer jet positions. Check condition and function of safety belts. Oil hood, trunk/tailgate, and door hinges. Grease hood, trunk/tailgate and door latches. Check operation of all latches. Check central locking/double lock. Replace microfilter or Acc Cabin Filter. Check heater/air conditioner blower, rear window defogger. Check rear view mirrors Visually examine the SRS airbag units for torn cover, obvious damage or attachment of decals, decorations, or accessories. Final Inspection Road test with check of brakes, suspension, steering, clutch/manual transmission or automatic transmission
05-31-2005, 03:51 PM | #6 |
