07-31-2011, 12:11 PM | #1 | |
starter just clicks 2003 monte carlo ss
was stranded with the car yesterday
went out to start the car the starter just clicked battery cables where loose just alittle jump started car and ran fine got home tightened cables before shutting off let it run for another 20 min and then shut off and tryed starting again Nothing but clicking from starter tryed putting a charger on battery nothing but clicking removed starter and had it tested Starter checked out ok No matter what i do it will not start Just clicks no security light at all Any help we are stranded at home and need some advice thanks |
07-31-2011, 01:41 PM | #2 | |
Re: starter just clicks 2003 monte carlo ss
i would start by checking the battery,with everything you did & have checked
its possible the battery has failed.you can do some tests with a v/meter,check voltage on battery & check when turning to start see if the volts drop off. you ck starter but does it have 12v to the solonoid?if the battery is original chances are the battery needs replacement.
Live For Today Yesterday is gone, Tomorrows are'nt promised. |
07-31-2011, 04:11 PM | #3 | |
Battery is only a year old and with a battery charger it still just clicks
even when by passing battery |
07-31-2011, 04:41 PM | #4 | ||
especially if its a trical charger.if the starter is clicking than more than likely your getting the power to it & you've already had starter tested but still may want to check its getting 12v .clean all connections & charge the battery for atleast an hour or remove it & have it tested
07-31-2011, 06:03 PM | #5 | |
sorry just hot and fustrated
i used one of the post next to the relays on the passenger side is what i meant and im using a high powered battey charger 12 volt high so im sure im getting enough from it to at least start it if that was the problem sorry not used to working on the newer cars this one has been bullet proof till now but 180,000 they dont last forever is there a starter relay or a fuse or multiple of them Explain how to test voltage at starter do i need someone to turn key while im doing this/?? thanks for the help |
07-31-2011, 06:35 PM | #6 | |
im sure there are relays ect. hopefully someone will have a diagrahm.
you can check fuse box under the hood for breakers/fuses with a volt meter see if you have 12v at the starter solonoid when trying to start (at the S terminal purple wire)
08-02-2011, 03:06 PM | #7 | |
checked the battery in the morning
it tested just fine after tearing out the dash putting in a new ignition and then a new starter still nothing then decided to just try a new battery for kicks and there it was just the battery why the load tester said it was fine is beyone me but thanks for all the help Back in business again |
08-02-2011, 03:36 PM | #8 | |
glad you got it,thanks for sharing the fix
