| Latest | 0 Rplys |
General news, articles, other. |
11-29-2001, 12:09 AM | #31 | |
ZAP ZAP baby.......
nightmaR3Z |
11-29-2001, 03:27 AM | #32 | |||||
Octane 101
you're all crazy !
"The Accord took a tiny step backward in power (minus 2.6 percent) and performance (minus 1.5 percent) on premium fuel" -Car & Driver Quote:
I have a foot made of osmium and i can get 275 miles to the tank easy. plus i live in the rockies. (fyi, osmium is the densest metal... so you can imagine how my foot presses down on the accelerator) true that is a bone stock P11. but that's besides the point. no, the point is that if an engine requires 87 octane, then anything more than 87 is a waste of money. and no, regular gas doesnt burn faster than premium gas... ive never heard anything so stupid, but i can imagine where that misconception might have come from. premium gas is required for high-performance engines because of the high temperatures and compression ratios that are associated with them. premium gas has a higher resistance to combustion than does regular gas... thus ALLOWING (NOT MAKING) the engine to make more power, SAFELY (as in, no knock/detonation - engine killers). so when you think about it... if youve got an engine tuned to take advantage of 87 octane (ours), and you put 93 in it... if anything... the fuel would be LESS likely to burn more efficiently. i quote Car & Driver: "Mind you, premium fuel does not necessarily pack more energy content than does regular. Rather, it allows more aggressive engine designs and calibrations that can extract more power from each gallon of gasoline. An engine's tendency to knock is influenced most by its compression ratio, although combustion-chamber design also has a large effect. A higher ratio extracts more power during the expansion stroke, but it also creates higher cylinder pressures and temperatures, which tend to induce knock. In supercharged engines boost pressure behaves the same way. That's why the highest-performance engines require higher-octane fuel. And finally, if a car calibrated for regular fuel begins to knock on anything less than premium or midgrade, owners should invest in a tuneup, emissions-control-system repair, or detergent additives to solve, rather than bandage, the root problem. Class dismissed." Last edited by Brian P; 12-01-2001 at 12:19 AM. |
11-29-2001, 03:34 AM | #33 | |
of course if you actually have done some mods to your engine... like advancing the timing for one thing, then by all means, you might just need a higher octane.
11-29-2001, 06:38 AM | #34 | |
Well I am gonna put a turbo in and hopefully run between .8 to 1 bar of boost. What would need to do to the engine besides ECU, exhuast and intake to support levels like that?
"God Bless BASS, What Would We Do Without It?" "If You Can Breathe, Turn The Music Up." |
11-29-2001, 07:45 AM | #35 | |
87 oct is fine for SR20 in stock form. But what you can do to increase power a bit thru your powerband is. This is for all SR20 N/A motors. You can advance your timing from a stock 15 deg advance to 17-19 deg advance and run 91 oct and you should see anywhare form 3-5 Wheel HP gain. You will also the car will diliver power much more smothly.
Chris Allen (North San Deago.) 96 200SX GTIR Powerd 497WHP on C16 351WHP on 91 oct pump gas - 92 Sentra SE-R Almost stock - 91 NX2000 SR20VE VVL Powered 177WHP almost stock (Girlfriends Car) |
11-29-2001, 08:07 AM | #36 | |
I noted how one of your cars had nearly 500 whp.
I want that to be my G in a year or so............
11-29-2001, 08:14 AM | #37 | ||
11-29-2001, 08:23 AM | #38 | ||
Mustang Cobra MAF MSD 50LB/HR Injectors JWT Fule rail to support the MSD's JWT ECU Reprograming for the MAF and Injectors. Or... You can order the FMAX turbo kit and it comes with all of that for 4500 bucks.. and you should see about 320 WHP @ 22 PSI of boost. Thats about all you need in the way of supporting what you want to do.
11-29-2001, 08:25 AM | #39 | |
Geeeeeeezzzzzzz, I'm in the military. I have money but not like that.
I give a couple of years then.........
11-29-2001, 09:14 AM | #40 | ||
Re: Octane 101
What month of Car and Driver did you find that article? :coolguy: :coolguy:
USA-love it or leave it!!!!! :coolguy: :coolguy: "Tis been my observation that a man that freely gives eveyone a piece of his mind ususally has very little left to think with." |
11-29-2001, 07:37 PM | #41 | |
So Brian P, I'm high huh? Then you say if I did mods and advanced my timing than it's O.K.? Did you see the pic? Yes, I have just about every bolt-on for a P10 AND have my timing advanced just a little. So quit with the typers rage.
Lastly, I KNOW that theres a difference between throtlle response and true hp, thus I know when there is a difference in the way my engine runs. I never said my car was faster. I simply said I DEFINITELY noticed a difference (this was before all my mods mind you). And no it wasn't cheap gas to good or anything like that. Same station, same pump, different grade. Ease off everyones back, not even Car & Driver know everything. Smarter.....depends on who you ask.
nightmaR3Z |
12-01-2001, 12:31 AM | #42 | |
the article says November 2001.
here is the link http://www.caranddriver.com/xp/Caran...e_gasoline.xml there is no reason why hp OR throttle response should change just because of the grade of fuel. i may have taken your quote out of context. i dont know. i just assumed it refered to a stock SR20DE motor. but i'm standing by my statement. running a higher grade fuel in a stock SR20DE isnt going to make *any* difference, other than how much cash is left in your wallet. you say i'm wrong. fine. i'd just love an explanation as to why... but not some "because i put 93 in my car and it felt faster." or "more resonsive" or even got faster times, as times can vary just because of the margin of error - many uncontrollable, such as atmospheric conditions. you say C&D is also wrong. a bold statement, but also fine. i would just love to hear a scientific explanation, not anecdotal evidence. |
12-01-2001, 12:27 PM | #43 | |
Read again, nothing in my previous post should've lead to anything that you just said. Especially, that C&D is wrong. Like you said, and what I meant; margin of error.
nightmaR3Z |
12-01-2001, 02:08 PM | #44 | |
Guys, there's a lot of monkey dung being flung around here. Read the gasoline FAQ.
http://www.landfield.com/faqs/autos/gasoline-faq/part1/ High octane will not harm your car. Octane ratings are different in North America from the rest of the world. In North Americal it's an average of Research and Motor Octane Numbers (RON and MON) and that is why you see (R+M)/2 on the pumps. The rest of the world uses RON. For most people, higher octane is a waste. There are things that can be done that take advantage of higher octane numbers that will add to performance, but higher octane numbers by themselves will do nothing. Higher octane number fuel can be good if you are trailering or driving on a lot of hills for extended periods. It will keep the engine from pinging or detonating under heavy loads and over time this will can be an advantage.
George Roffe Houston, Texas USA 00 328i 91 SE-R (well modded) 84 944 SCCA ITS race car under construction "I fear all we have done is to awaken a sleeping giant and filled him with a great resolve" -- Admiral Yamamoto, December 7, 1941 |
12-01-2001, 04:08 PM | #45 | |||
Colin Gillespie - 1993.5 Nissan Primera - NWG20s |
