Go Back   Automotive Forums .com Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 06-22-2014, 05:59 PM   #1
jawbone
Cool 4thgen 95 maxima no start
Hello everyone I have a 95 Nissan maxima with a manual transmission . The problem is a no start, I tried everything starting with the starter, new battery ,alternator, crank sensors and new spark plugs . its getting gas but spark test with coil pack no spark , how ever it will start if I pop the clutch any suggestions?
jawbone is offline   Reply With Quote
Old 06-23-2014, 01:41 PM   #2
Nahkapohjola
Nahkapohjola's Avatar
Re: 4thgen 95 maxima no start
Originally Posted by jawbone View Post
... but spark test with coil pack no spark ...
- If fuel supply ok, injectors do click at right timing. Listen click with stethoscope or using long screwdriver... If clicking, ECU is not totally dead.
- at startup, all injectors open simultaneously causing fuel smell - when NOspark
- if no spark, useless to try anything before that one is corrected: ECU drives 'em coilpacks. First check, measure all fuses.
Then check for healthy supply voltage at ECU pins.
- run self diagnostics
- read ECU codes
Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507
There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14
Nahkapohjola is offline   Reply With Quote
