Go Back   Automotive Forums .com Car Chat > Kia > Sportage
Old 04-15-2017, 01:47 PM   #1
Redneckscot66
Redneckscot66's Avatar
Brake problems
I have a 2001 sportage that i had to replace both front calipers and while i was bleeding the brakes i notice the fluid was bubbling in the reservoir. Is this normal? also my brake pedal does feel right either. Help PLEASE
Redneckscot66 is offline   Reply With Quote
Old 04-19-2017, 12:05 PM   #2
rhandwor
Re: Brake problems
If you have anti lock brakes You will need a scanner to properly bleed.
rhandwor is offline   Reply With Quote
Old 04-21-2017, 09:18 PM   #3
Redneckscot66
Re: Brake problems
I do not have anti lock brakes.
Old 04-22-2017, 03:22 AM   #4
rhandwor
Re: Brake problems
I think you have air in the system try to bleed all 4 wheels do back first then the front. You need to put the vehicle on four jack stands bleed each wheel three times. You can also use a vacuum bleeder.
Old 04-22-2017, 11:50 AM   #5
Redneckscot66
Re: Brake problems
My back brakes are drum. is there an auto parts store that rents vacuum bleeders?
Old 04-22-2017, 11:55 AM   #6
Redneckscot66
Re: Brake problems
I also see brake fluid bubbling in the reservoir while someone is pumping the brakes.
Old 04-27-2017, 03:01 AM   #7
rhandwor
Re: Brake problems
The bleeder for the drum brakes is on the wheel cylinder. Call and ask parts stores for a loaner. You can purchase a vacuum kit if you have a vacuum pump.Lisle makes them.
Old 05-12-2017, 09:58 AM   #8
LMP
LMP's Avatar
Re: Brake problems
Is the problem solved...or was there a problem, finally?
I had to change metal tubing to the rear brakes and bled from the end of the line connector, with success. WHeel cylinder bleeders happen to become too hard to unlock .
My 2000 sportage, alas, is now defunct....those authentic KIA production models were so prone to corrosion that it was falling in pieces....body and frame...
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
LMP is offline   Reply With Quote
Old 08-06-2017, 02:14 PM   #9
Redneckscot66
Re: Brake problems
I ended up not doing anything with it cause the engine blew up
Tags
brake , problems
