Thread Tools Search this Thread
Old 12-06-2013, 05:24 PM   #16
JeremyJon
JeremyJon's Avatar
Re: McLaren F1-GTR short tail by MFH
Looking good LD!
I've not worked much before with white metal parts in kits, I really prefer resin/plastic, I suppose that's why I still have a couple of gunze high detail kits sitting on the shelf LOL
JeremyJon is offline   Reply With Quote
The Following 2 Users Say Thank You to JeremyJon For This Useful Post:
Maranello1977 (06-08-2014)
Old 12-06-2013, 08:20 PM   #17
stevenoble
stevenoble's Avatar
Excellent start, it's coming together very nicely. I feel though that for the price of these kits, the fit should be better..?? I know that they are not as easy to build as a plastic kit. But it always amazes me how, with a multi media kit, bad fit is expected, maybe even accepted on some level. But if the same were true of a plastic kit it would be labelled as a "bad" fitting kit.
Good luck with the build, I'll follow your progress with interest...
Steve Noble
stevenoble is offline   Reply With Quote
Old 12-07-2013, 02:21 AM   #18
Shunter
Shunter's Avatar
Beautiful looking car and an excellent start.
Cheers
Shayne
http://motorsportmodeller.blogspot.com.au/
Shunter is offline   Reply With Quote
Old 12-09-2013, 01:45 PM   #19
lezdep
Originally Posted by stratos75 View Post
Hey, lezdep, your progress is not so big compare to mine with my copies.
I think I'm catching up a bit. Had magnetic tumbler running last Friday for about 4 hours and got most of the parts
cleaned. Only big parts remain to clean manually, because they wouldn't fit into tumbler. I've permanently assembled engine
and gearbox parts, before painting. I was tempted to leave them as they came out of tumbler - shiny. But on real car engine
is aluminium color and gearbox is steel color. So, will have to prime and paint these 2 sub-assemblies and other parts.
After clean up number of imperfections appeared in metal parts. There are also imperfections in resin parts, I will have to fix.
They cycle of priming/sanding/priming can take long time. So, it could be a while before next updates in this WIP appear.
lezdep is offline   Reply With Quote
Old 12-09-2013, 04:15 PM   #20
stratos75
None of finished WIP ;)
stratos75's Avatar
I do not understand what this cleaning was done for? To my opinion metal parts from box looks ready for painting without any cleaning works. They needs only in some adjustment works and to smooth out traces of mould junctions.
Can you show me more close what is the parts surface you receive after cleaning. For example like this:
http://img-fotki.yandex.ru/get/9324/..._ae68e872_orig
http://img-fotki.yandex.ru/get/9503/...0_d4ed681_orig
Best regards, Mikhail
stratos75 is offline   Reply With Quote
Old 12-09-2013, 05:31 PM   #21
ianc911
What is this parts-cleaning tumbler of which you speak? Have not heard of this before. Can you give a URL? Thanks for any info,
ianc
ianc911 is offline   Reply With Quote
Old 12-09-2013, 09:45 PM   #22
lezdep
I have different opinion on cleaning up the parts. I clean mold lines and a bit of extra metal sprouts. Tumbler then makes surfaces quite
a bit smoother. It is specifically useful for small parts, when sanding by hand is difficult. I have not taken photos of before and after specifically.
I'll try to get comparison photos next time.
ianc
The one I have is very similar to this - http://www.ottofrei.com/Best-Built-V...-Polisher.html "How it works" section explains principals it works on.
The Following User Says Thank You to lezdep For This Useful Post:
stratos75 (12-10-2013)
Old 01-04-2014, 01:27 PM   #23
lezdep
Finally an update. Work has not stopped on this kit, but because current steps are preparations and painting it takes long
time to get something worth showing. To not bore you with many photos I've made 2 collages depicting priming and painting
steps. I have more small parts to be painted. Body panels will have to be checked for surface imperfections, primed with
white primer and then I can start painting body colours for the FINA livery and apply decals.
First photo is of primed parts.
Second photo is of painted parts.
Old 01-04-2014, 06:40 PM   #24
bradfordian
If you carbon fibre the interior it will look brill?
bradfordian is offline   Reply With Quote
Old 01-25-2014, 01:47 PM   #25
lezdep
Almost 3 weeks without updates, but there is progress and this build is moving ahead. Just not as
fast I would have liked. Done quite a bit more painting. Bought 4 different shades of gold and metallic
yellow. Yet not a single one looked like real colour or suspension arms. Used the closest one I had.
Done some washes on engine elements. I've used Tamiya smoke over aluminium. Not sure what to
use for a wash on gearbox. It's painted in steel colour. I guess I need some kind of diluted silver wash.
No photos of body parts, because they are being prepared for white primer. While I like exhausts painted
in stainless steel, they do not look realistic that way. Bought Alclad Exhaust Manifold paint and plan to
use it in attempt to get colour closer to original.
There is so much carbon fibre exposed on this car. I'm still deliberating on how much effort I would want
to put in it and what would be the minimum set of parts "carbonized" I could get away with.
Old 01-25-2014, 01:55 PM   #26
eyckles
eyckles's Avatar
Hi Sergey,
Very nice update. The painted parts look amazing. About the CF. I would do as much as i can. Just an opinion of course. Keep up the good work.
Best regards,
Lesley
eyckles is offline   Reply With Quote
Old 02-12-2014, 03:08 AM   #27
Jirka K.
Hello!
Its very nice progress. This MM kit is superb!
I have a small question for all...
Does anyone know whether the kit includes parts for other versions??
If the default kit the same for all versions, the only other decal options??
Sorry for my crappy english
Jirka K. is offline   Reply With Quote
Old 02-12-2014, 04:05 AM   #28
stratos75
stratos75's Avatar
Originally Posted by Jirka K. View Post
...I have a small question for all...
There are two types of the MFH's kit: one is for versions A, B, C and the second is for versions D, E. The main differences are in the suspension arms and the rear wing. You can choose one of them for the different liveries you want to apply. The differences you can see in these scans of the instruction.
Old 02-12-2014, 05:02 AM   #29
Jirka K.
Thank you very much for the quick reply.
Now it seems already clear
There are two versions of the kit, but only one version of instruction.
Thank you very much
Old 02-12-2014, 05:15 AM   #30
stratos75
stratos75's Avatar
You have understood me right. The assembly instructions are identical excluding the title and the last pages, in which the current version has shown. For example, this is the last page of one version.
Bookmarks
Search this Thread:
