| Latest | 0 Rplys |
03-05-2010, 09:01 PM | #1 | |
1998 T&C battery light on not charging
The battery light came on, alt not charging. I have taken it off twice and had it checked, both times I had it checked it showed good, when I put it back on it charged for a bit and then the light came back on and it showed no charging at the battery. Second time the place checked it they ran the check cycle 4 times in a row to see if it had a problem when the electronics started warming up... still showed all green.
I thought perhaps the wires going to the alt, so I had the wife start the van up and I moved the wires around going to the alt to see if it made the batt light flicker, no joy. (real fun getting your hand back there while the van is running) The large wire shows batt voltage where it hooks on to the alt, running or not...... the two prong plug that goes into the alt shows no voltage unhooked with the key on, and no voltage plugged in with the key on or running. I have been told there is a control unit that controls the output of the alternator. I have checked every fuse in the fusebox under the dash and in the engine compartment. Fuseable link on big wire going to the alt should be good as I do get battery voltage to the alt from the battery, correct? Any suggestions? |
04-12-2013, 05:22 PM | #2 | |
Re: 1998 T&C battery light on not charging
Well, OF COURSE NOBODY ANSWERED YOU! Because I need an answer to the same question and your question is the only place I've found with the same freakin' problem.
AF is getting so out-dated. I used to find answers here all the time until about a year or so ago where it seems like nobody is posting or reading anymore. I hope YOU got the problem figured out. Meanwhile, I'm going to search some other sites. Thanks for posting it and trying to get an answer for us.
2002 Grand Prix GT 3.8 V6 1998 Dodge Grand Caravan 3.3 V6 1998 Chevy Blazer 4wd 4.3 V6 |
04-12-2013, 06:18 PM | #3 | |
Man this is a blast from the past.... I ended up going to a pay site where you can ask master mechanics a question for a small fee, was told no matter that they were telling me alternator was good, to change it. He was right, new alternator its been running fine since.
04-13-2013, 11:42 AM | #4 | |
AF -Advisor
Sounds like a familiar scenario over the years. Charge system testing is far from conclusive. Thanks for posting your fix.
BTW - You can save some bucks and rebuild your alternator using a kit instead of replacing it: http://www.youtube.com/watch?v=CImyX5KuGvQ
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds. **Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual. 07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan |
04-13-2013, 05:23 PM | #5 |
12-18-2015, 02:24 PM | #6 | |
I had the same problem. If you check with your car parts stores you will find their alt testers are good for checking bearing noise but the testers are no good if they don't run a load test. If the alt can't generate a load current they are no good.
12-18-2015, 02:30 PM | #7 | |
That's true, found it out the hard way LOL Like I said, changed the alternator and all was good. Of course since then, my daughter totaled the van so...........
