| Latest | 0 Rplys |
06-09-2006, 10:02 PM | #1 | |
Bad alternator or battery?
Hello everyone.
The problem that I am having is that I cannot tell if my vehicle is suffering from an alternator or a battery problem. I own a 01 GMC Jimmy 4.3. What happened was this: As I was pulling out of a parking space, my battery light went on, and my car just stalled. The lights were still on, so I put the car into park, and then everything went out. I couldn't get my key out of the ignition, the lights wouldn't turn on, and I couldn't put the truck into any other gear. Then I got out, popped the hood, and put the support up. Once I did that, then the lights went back on. I went back into the car, put the key in the ignition, and attemped to turn the car on. The lights went on, the starter kicked, but the car wouldn't turn on. After a couple of minutes, the car then turned on, and I drove home. Now, what do you think could be the problem? Alternator or battery? I just purchased a new battery about 2 months ago (maybe a bad cell?). Also, I had the air conditioner on when this happened, so maybe that was a factor as well? Any help would be greatly appreciated! |
06-11-2006, 08:57 AM | #2 | ||
Re: Bad alternator or battery?
06-11-2006, 03:17 PM | #3 | |
Actually, it was raining cats and dogs the night it happened. So then it would most likely be a short?
06-11-2006, 07:32 PM | #4 | ||
Easy temp fix to see if it's the issue? -inspect the cap\wires for damage. None seen? Then buy a can of ignition protectant from autozone\canadian tire or the like and spray the heck out of your plug wires and dist cap. Keep driving as usual and wait to see if the problem shows up again (without rain) or if it does re-appear with rain re-spray the parts to seal them and maybe even spray the ECM (the computer). I've sprayed many of my distributors and had the problem go away instantly. Of course if you don't know the last time the cap\rotor\wires have been done it can't hurt to do em anyways and then spray them ontop of that. hth |
06-17-2006, 01:37 AM | #5 | |
If your battery light came on it indacated that the battery circuit was shorted in some fashon. I would first check the 175 amp fuse under the battery box on the rad support. You might have a bad connection there. Second I would bring your truck Or your alternator to an alternator shop(NOT the dealer) and have them test the regulator. These trucks have a 130 D alternator and have one of several regulators in them that are very sensative to shorts and surges. If the regulator goes there is a possibility of sending 3phase AC power into your vehicle's system. this will cause all kinds of problems ASK ME HOW I KNOW. You can easily check your battery by bringing it to VIP or other shops like that and have them load test it.
Good luck Nick
2003 S10 Chevy 99 GMC Jimmy 91 GMC Jimmy 88 Gmc Jimmy 1959 FLH Harley 1984 Honda Goldwing |
12-03-2011, 12:05 PM | #6 | |
hi i have a 98 monte carlo and it started with my voltage light coming on. so i took it to auto zone and had the battery tested and the alternator. they said they seemed to think it was the connection wires so after cleaning those it was just fine. the amps read the same coming and going from the battery and alternator. but when i went back out to start it again i started having the same problem. even purchased a new battery and that didnt fix it... one time it works fine and then the next the light comes back on and my inside light will dim along with my head lights when the car is given gas... any suggestions on what to do now????
thanks alot |
12-04-2011, 03:44 PM | #7 | |
you should really re-check battery terminals for a poor connection,,,check alternator output with a vom ,,,engine running,, lights,,,blower ,,on,, voltage should read 14 volts or better,,,battery should read 13.5 volts with car shut down,,,nothing running.....
If alternator reads below 13.5,,,there is a problem with it..... |
