Old 12-17-2005, 12:36 PM   #1
Orangeguy
Orangeguy's Avatar
06 Mustang Question
Any ideas on how I could cleanly cut this bottom grille out?
Anything will help.
Orangeguy
Orangeguy is offline   Reply With Quote
Old 12-17-2005, 12:47 PM   #2
Lambo003
Lambo003's Avatar
Remove material slowly from the rear (back side) by sanding or grinding.
Chuck
Lambo003 is offline   Reply With Quote
Old 12-17-2005, 07:46 PM   #3
73superduty
Lost in plastic
73superduty's Avatar
Lambo's idea will work perfect. Although I did mine by doing the following:
I used a pin-vise and drilled about six holes, 3 on top and three on the bottom and used a new #11 blade and cleaned out the rest. I then used a needle file to sand it smooth.:
Always more than one way to skin a cat so to speak.
Chris
73superduty is offline   Reply With Quote
Old 12-18-2005, 03:04 AM   #4
Lambo003
Lambo003's Avatar
Yup! sure is!
That's the great thing about these forums! You get several perspectives and then can pick & choose which one ya feel comfortable to go with.
Nice clean grille work there BTW!
Chuck
Old 12-18-2005, 10:03 AM   #5
Orangeguy
Orangeguy's Avatar
Re: 06 Mustang Question
Where exactly did you drill the wholes 73superduty?
Orangeguy
Old 12-18-2005, 05:15 PM   #6
73superduty
Lost in plastic
Re: Re: 06 Mustang Question
On the front side, just anywhere as long as you get them close to eachother. This way you have some of the material removed and you can get your exacto blade to start removing the rest of the material.
Just be careful not to get too close to the seperator bar. Take your time and go slow.
Chris
Old 12-20-2005, 08:10 AM   #7
HittenSwitches
HittenSwitches's Avatar
Send a message via MSN to HittenSwitches
Whenever I take the doors or trunks or grillz etc. off of my cars, I use a needle...and sort of needle really but a good one. My exacto knife kit comes with pin shaped heads that attach to the knives. I guide the pins across where i want the plastic cut. I repeat this process many times, and you can see the plastic "shaving" off everytime you scrape at it. It works great, i do it all the time. Eventually it will go through and then just use and exacto knife to continue the rest of the way, and use sanding paper to smooth it out
Mods:
Aqua blue neon undercar kit by Eurolite
Neo Blue Streetglow 9" tubes under driver and passenger seats
Pioneer head unit
12" 300 watt Rockford Fosgate Sub n amp
Carbon Fiber interior panels
Plenty more coming
HittenSwitches is offline   Reply With Quote
