| Latest | 0 Rplys |
12-23-2016, 07:29 AM | #1 | |
2002 Suburban 2500 Rear Gas Tank
I have run into a problem of my 2002 Chevy Suburban 2500 rear gas tank needs to be replaced. We have the main gas tank and then the one in the rear that is above the spare tire. Each tank has it's own fuel filter. Attached is a picture of the tank. Does anyone know where to get a replacement tank?
12-23-2016, 09:20 AM | #2 | |
Registered Offender
Re: 2002 Suburban 2500 Rear Gas Tank
Welcome Aboard!
I believe these had plastic tanks, correct? The aftermarket doesn't seem to offer much, but a salvage yard might have one. Since a plastic tank would not rust, it should be safe to install a salvage tank without worries. Also, if the tank is cracked or split it might be repairable. Many places can weld plastic.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
12-23-2016, 02:39 PM | #3 | |
Thank you, the dual exhaust broke off and we drove it without it on there and the heat from the exhaust melted it a little, so it's a bit disfigured and a small hole. I was going to put some JB Weld for plastic on there but didn't want to waste my time if we could find another one.
12-23-2016, 09:27 PM | #4 | |
Registered Offender
Epoxy may not work very well. The tanks are usually polyethylene and most epoxies don't bond to that very well, JB Weld included. A welded-on patch would likely be more reliable, but if you find a good used one that would surely answer it.
