Old 10-21-2005, 01:13 AM   #1
Jurva
Jurva's Avatar
Post How-To: Turbo, easy way
Here is a easy way to make turbos, using cheap parts. Please tell me if there are big writing mistakes.
Making of turbines
2 different sizes and ways.
1. Heat and bend some straight pipes from parts trees. If you want bigger turbine, use some tubing. Also straw could be used.
2. Cut away another pipe.
3. Heat again and align that turbine.
Different ways to mockup
1. Fresh air intake
2. Compressed air goes into engine, through the intercooler, or straight
3. Exhaust manifold hooks up here. It will spin that turbo.
4. Exhaust pipe exit.
Here is bigger turbo. Two pipes are bent around a brakeline pipe. Also straw, aluminium pipe or something like, could be used.
Smaller turbo mockup. Exhaust turbine, placed into exhaust manifold, made out of solder.
Glue the middle part to exhaust side. You can place turbo oil lines there.
Glue compression turbine to rest of the turbo. I used velocity stacks, from some carbureted engine. You could use air cleaner or straw in here too.
Example of 4-cylinder engine.
Completed:
Top Secret Supra
Jurva is offline   Reply With Quote
Old 10-21-2005, 10:59 AM   #2
SteveK2003
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
Re: How-To: Turbo, easy way
Nice how-to, thanks.
SteveK2003 is offline   Reply With Quote
Old 10-21-2005, 03:36 PM   #3
SupaMan89T
SupaMan89T's Avatar
Send a message via AIM to SupaMan89T Send a message via MSN to SupaMan89T Send a message via Yahoo to SupaMan89T
good how to not people know how to hook the whole system up too because of the last pic we've been needing that on this furom!
Project Lexus Revive
SupaMan89T is offline   Reply With Quote
Old 10-21-2005, 03:43 PM   #4
D_LaMz
D_LaMz's Avatar
Thanks, but I have already tried this and its toohard for me because of the sharp bend.
D_LaMz is offline   Reply With Quote
Old 10-26-2005, 03:24 AM   #5
Jurva
Jurva's Avatar
There is a lot of detailling you could add to your turbo engine. Vacuum lines, oil lines, clamps etc.
Here is very good picture of wastegate vacuum line.
http://www.turbosaturns.net/articles/wastegate101.htm
BOV vacuum line is easy. Just hook it up to intake manifold, after throttle body.
Completed:
Top Secret Supra
Old 12-02-2009, 01:04 AM   #6
kingalbrect79
kingalbrect79's Avatar
Try the bend with a longer piece of sprue, then cut it off, you don't have to use a piece just long enough. Make it easy on yourself so you have something to grip with.
Also if you want to smooth out the turbo sides without having to sand them so they look perfectly round, as you bend the sprue around the pipe, pull it slightly so that it stretches.
You might have to use a bit larger sprue than normal because the diameter will shrink when you do this, but it will be perfectly smooth when your done with no modification!
If it runs, i'll race it.
kingalbrect79 is offline   Reply With Quote
Old 12-02-2009, 03:31 AM   #7
TurboGuru
TurboGuru's Avatar
hmmm TurboGuru finds this thread very helpful!
TurboGuru is offline   Reply With Quote
Old 12-02-2009, 07:24 PM   #8
rsxse240
I have posted MS paint turbo diagrams at least twice...but no one ever pays attention to my posts. haha
This is a very good idea, and you can build LOTS of turbo for free! because we all know that you never throw away plastic if you are a scratch builder.
