Go Back   Automotive Forums .com Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 12-07-2011, 12:21 PM   #1
1st dodge
1998 Ram no start code P0340
i have a 1998 ram 1500 4x4 318, it will turn over but not fire.
i have replaced the following:
cap, rotor, camshaft sensor / pick-up coil was told they were same thing??, crankshaft sensor finally got my hands on a code reader. NO LINK.
towed it to a shop specializing in electrical.
told computer was bad, had new one install. ran great drove it home, to work next day, stopped for fuel.
now it wont start, same type problem. turns over no fire.
this time coad reader says P0340,
any suggestions???
1st dodge is offline   Reply With Quote
Old 12-08-2011, 01:32 PM   #2
1st dodge
Re: 1998 Ram no start code P0340
now it started right up, didn't do anything but turn the key.
so i drove it home, cleared code, double checked connection for camshaft sensor. so far so good, it still starting every time.
could i have a weak battery?
Old 12-08-2011, 05:47 PM   #3
Chris Stewart
AF - Advisor
Chris Stewart's Avatar
P0340 No Cam Signal At PCM.
No fuel sync.
If there's enough battery energy to crank the engine over a pretty good clip, there should be enough energy to operate the electronics imo.
1992 Bravada, 201K, stock
1997 Bravada, 101K, stock...was "called away"
"Cornbread Red", 2001 Dodge 2500,4X4,HO Cummins Diesel,QC,SWB,6spd.,Banks boost&pyro,US Gage fuel press.,Edge Drag Comp,4"exh.,cowl hood, bhaf, black Holley pump, 140gph...13psi WOT, Vulcan Big Line, kevlar/ceramic single disc clutch, cheapo fuel cooler, 8x.010" vco injector nozzles, Cat turbo 62-65-.70A/R, 497hp 1089 tq 8/25/14
Time to turn so's you don't burn.
Chris Stewart is offline   Reply With Quote
Old 12-08-2011, 09:48 PM   #4
1st dodge
it does turn over at a good clip, volt meter reading 12.6 and if it starts reads 14.
acted up again tonight. turns over no start, threw code p0340 again.
should i put old cam sensor back on and see if it helps?? could there be something wrong with new computer??
p0340 code fireplow E Series 1 04-24-2011 10:14 AM
1998 Ram 1500 Fails To Start colorado69 Ram Pickup | Ram SRT10 8 12-16-2005 09:32 AM
98 ford escort zx2 code P0340 cam shaft position sensor danadane41 Sable 1 12-04-2005 06:01 PM
1998 Ram 1500 5.9L Slow Start jpwheeler Ram Pickup | Ram SRT10 4 08-04-2005 12:50 PM
Code P0340 Cammshaft Position sensor circuit malfunction sierraaa Mirage 1 09-24-2004 03:19 AM
