Originally Posted by nova72
Yes, it has a K-H 4WAL abs system. My understanding of the combination valve is that if the rear circuit fails, the valve will limit pressure to the rear and allow full pressure to the front.
Also it can limit pressure to the front.
Three thins will give you a red waring light .
emg brake or low fluid if you have a low fluid switch.
If red warning light is on for a test on it unplug it from the combination valve and see if light goes off.
That system is hard to bleed.
To bleed you need 3 combination valve depressors to hold valves centered.
If air has got into the ABS unit there is 1 or 2 internal bleed valves you need to rotate to bleed thae ABS system.
Make sure rear wheels are adjusted up good .
Then Try bleeding all 4 wheels and see if you get good pressure to all 4.
If you can get the three combination valve depressors to aid in bleeding.
Also.
If all else fails get a All data online sub or a factory repair manual on bleeding.
http://www.alldata.com/products/diy/index.html
They have the instructions for the internal bleed valve bleeding.
Good Luck
