Car Audio Do you live in your car? Then you need to be able to listen to some high-quality music. |
02-01-2005, 07:42 PM | #61 | |
Re: Subwoofer Setup
every 2" is a little overkill just make sure the wood doesn't split..... it makes the box weaker in the spot.
2002 Ford Explorer Limited D31 yellow top Kenwood DDX-7017 2 Ascendant Audio Avalanche 18's 13 cuft NET ported box tuned to 27hz Autotek Mean Machine MX3000.1 Ascendant Audio Arco component set Orion 275SX (Mids) PPI Art Series A200 (tweets) Poly Mids for rear fill to come soon. |
02-01-2005, 08:37 PM | #62 | |
Re: Subwoofer Setup
if i add component 6x9s to the rear door panels, will that ruin the fell and SQ of the subs?
02-01-2005, 10:32 PM | #63 | |
Re: Subwoofer Setup
Anyone?
02-02-2005, 12:21 AM | #64 | |
Re: Subwoofer Setup
I didn't get your question...........but a lotta ppl don't run rears and there's no need to unless you ahve a big SUV
02-02-2005, 06:47 AM | #65 | |
Re: Subwoofer Setup
No it won't ruin it unless you have them running out of phase. I don't upgrade the rear speakers but I am usually more worried about the front stage in a vehicle. Now if I am installing a system that has 6.1 surround output, I'll ofcourse upgrade the rear channels.
Silverado Ext. Cab 4x4 z71 Pioneer 4900mp Orion P6.2 Componet sets front Orion C63 Coax rear DirectedVideo 9" all in one DVD with surround 2007 SATURN OUTLOOK AWD XR with full entertainment package |
02-02-2005, 08:02 AM | #66 | |
Re: Subwoofer Setup
ruin the SQ of the subs?
no ruin the SQ of the front stage? yes
'01 Black Sentra SE Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8 '05 Silver WRX STi Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials |
02-02-2005, 04:19 PM | #67 | |
Re: Subwoofer Setup
If you have a distribution block in your system, you still need the seperate fuse holder with amp right?
02-02-2005, 05:41 PM | #68 | |
Re: Subwoofer Setup
Anyone?
02-02-2005, 08:31 PM | #69 | |
Re: Subwoofer Setup
what?
you mean the fuse holder that's supposed to go up by the batt, if so then yes you still need that even if you have a distro block
02-04-2005, 04:39 PM | #70 | |
If i make a sub box which is relatively like this which from left to right will go like this (see bottom), well the amp be damaged?...
One subwoofer, then to its right a port, then to its right a mounted amplifier with plexiglass cover, then to its right another port, and finally the last sub. |
02-04-2005, 06:41 PM | #71 | |
Re: Subwoofer Setup
Anyone?
02-04-2005, 07:49 PM | #72 | |
Re: Subwoofer Setup
if your box is made sturdy and its braced on the inside.. then the amp shouldnt be vibrating that much.. if youre getting something loud its conna rattle anyways if its close to the box. a lot of people mount to their boxes and dont have any problems..
btu abotu the plexiglass cover.. amps need to dissipate heat.. and if its covered the heat is just gonna saty around the amp and itll prolly go into protection early.. if you have to have plexiglass make sure its well vented
1996 Explorer 4.0 V6 4x4 Sold all my shit. waiting for more money |
02-04-2005, 08:11 PM | #73 | |
Re: Subwoofer Setup
Ya i was thinking about adding some coputer fans under and next to where the mount will be sitting.
02-04-2005, 08:12 PM | #74 | |
Re: Subwoofer Setup
*where the amp will be mounted*
Thread Tools | |
