Go Back   Automotive Forums .com Car Chat > Honda > MDX | Pilot
Old 08-19-2016, 10:09 AM   #1
whw47
2005 Pilot - Water under dash (condensation)
Getting water under dash passanger side..not coolant. It must be from AC condensation....Where could the drainage be clogged?
whw47 is offline   Reply With Quote
Old 08-19-2016, 11:02 AM   #2
brcidd
brcidd's Avatar
Re: 2005 Pilot - Water under dash (condensation)
In the drain tube- have seen mud dobbers, wasp nest etc in drain tubes. All cars have one directly under evaporator- lok for evap pipes in and out of firewall under hood, then look directly below that for drain tube-- I've pull clog out before and got 2 gallons hitting the ground--use a pipe cleaner (remember grandpa had one- he smoked a pipe) to be safe
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
brcidd is offline   Reply With Quote
The Following User Says Thank You to brcidd For This Useful Post:
whw47 (08-20-2016)
Old 08-21-2016, 08:26 PM   #3
whw47
I was able to find the drain hose from under the car. Since I didn't have any pipe cleaners, I tried a tie strap but it didn't seem to be working so I tried a craft wire and I think it worked...The wire was damp although no water ran out but I think water that was there may have simply evaporated in the heat of the day because I was not driving the car for a couple of days ...I then drove the car with AC running for about an hour, When I got home, there was no moisture under the dash and the drain hose was dripping water.....Hopefully That fixed it.
Old 12-16-2017, 10:18 AM   #4
whw47
Using a tie strap to clean out the drain hose helped for a while but the problem reoccurred...I then got an air tank and using a piece of fuel hose, cleaned the drain hose with air pressure....Its been dong fine since then.
