Old 11-18-2002, 06:47 PM   #1
97gsr
97gsr's Avatar
Send a message via AIM to 97gsr
will switching oil types harm?
I bought my 97 gsr used and do not know if the previous owner used synthetic oil or not..
I have been using reg oil (not synthetic)...
Will it harm my engine at all to switch to synthetic...and if not, is it worth my $ to start using synthetic
might be a dumb ?
no flames please!!
TIA
97gsr is offline   Reply With Quote
Old 11-18-2002, 09:27 PM   #2
higgimonster
higgimonster's Avatar
switching to synthetic will not cause any harm to your engine. Only your wallet. A 97 GSR will be using non-synthetic and you should stick to it. Unless you completely dry out all of the oil from your engine and replace it with synthetic there is no reason to spend $3 a quart for oil. Just stuck with what your manufacturer specifies. there is a reason they specify that oil. They tested it to be the best for their engine.
Promoter of the one line signature.
higgimonster is offline   Reply With Quote
Old 11-18-2002, 11:05 PM   #3
civickiller
Send a message via AIM to civickiller
you can switch to synethic if you want. just drain out your old oil and put it in. thats what synethic blends are, synethic mixed with oil. so its ok to use synethic with your existing oil. just make sure you dont change weight. supposedly synethic is better, it help lubricat your enigne better or something.
civickiller is offline   Reply With Quote
Old 11-19-2002, 09:08 AM   #4
wagsaccordsir
wagsaccordsir's Avatar
Actually I've heard that the viscosity breaks down easily in synsthetic, and it practically turns to water and can leak through and saturate your rings and cause damage later on down the road.
I use 30D by Havoline..
MY ACCORD ON KENWOOD'S PHOTO GALLERY
MY ACCORD ON CARDOMAIN
"CHEAP THRILLS"
I DON'T CARE HOW MANY SKY DIVES YOU'VE GOT. UNTIL YOU'VE STEPPED OUT INTO COMPLETE DARKNESS AT 850' WEARING 95LBS. OF EQUIPMENT AND 68LBS. OF PARACHUTE. YOU JUST HAVEN'T LIVED.
ARMY AIRBORNE!!!
wagsaccordsir is offline   Reply With Quote
Old 11-19-2002, 10:22 AM   #5
97gsr
97gsr's Avatar
HEY THANKS GUYS!!!
Old 11-19-2002, 11:31 AM   #6
ivymike1031
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
It would be more accurate to say that they tested to confirm that it's "good enough" for their engine. That doesn't mean that there isn't something better out there. Keep in mind that $0.10 per vehicle in cost savings translates to $100,000/yr or more for an OEM.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
ivymike1031 is offline   Reply With Quote
Old 11-24-2002, 07:04 AM   #7
Freeman
Re: will switching oil types harm?
might be a dumb ?
no flames please!!
TIA
Mobil 1! I love this shit! Sure, it's 4 bucks a quart, but it WORKS!
My cars run so fine with it, and it's only $12+ bucks every three-
four months.
Freeman is offline   Reply With Quote
Old 12-07-2002, 09:02 PM   #8
lapspec
Unhappy Syn Oil
Freeman, Please be careful when listening to uninformed individuals in this forum. Synthetics are the best oil you can use in you vehicle. In regards to two of the post here: Higgimonster stated" Just stuck with what your manufacturer specifies. there is a reason they specify that oil. They tested it to be the best for their engine." Manufactures only recommend basic oil and sometimes synthetic, saying only to use an api rated oil. Each oil has different makeup properties and not all are good this is even the case with synthetics. In regard to wagsaccordsir comments. He should really get a better understanding of oil basics. He said: "Actually I've heard that the viscosity breaks down easily in synsthetic, and it practically turns to water and can leak through and saturate your rings and cause damage later on down the road.
I use 30D by Havoline.." This fact is not true at all. If you would like to understand oil better please look at my web site www.synthetic-lubricants.com and download the free preview of the motor oil bible. The preview itself will answer most of your questions.
George J Lapchak
lapspec is offline   Reply With Quote
Old 12-07-2002, 09:14 PM   #9
wagsaccordsir
Looks like somebody is trying to make a sale!! Buy AMSOIL products!! mmm???
"CHEAP THRILLS"
ARMY AIRBORNE!!!
Old 12-07-2002, 09:25 PM   #10
lapspec
Talking Sell Amsoil ?
"Educate first - sell later" I do recommend Amsoil however I do not get into arguments as to the best oil that is for the informed person to decide.....At least the facts I give are true and solid...
George J Lapchak
Old 12-07-2002, 09:48 PM   #11
wagsaccordsir
I never gave facts did I???
"CHEAP THRILLS"
ARMY AIRBORNE!!!
Old 12-07-2002, 09:58 PM   #12
wagsaccordsir
INSTEAD OF MAKING ME BUY THIS BOOK TO EDUCATE MYSELF WHY DON'T YOU SEND ME THE PASSWORD SO I CAN DOWNLOAD IT AND EDUCATE MYSELF SO WE CAN BOTH AGREE THAT YOU ARE TRYING TO EDUCATE AND NOT SELL A PRODUCT... IMPORTRACER151@EARTHLINK.NET
"CHEAP THRILLS"
ARMY AIRBORNE!!!
Old 12-07-2002, 11:46 PM   #13
ivymike1031
Well technically speaking, you probably did provide a factual account of what you'd previously heard. Unfortunately, what you've heard doesn't seem to be accurate.
Synthetic oils are, generally speaking, more resistant to degradation (shear and thermal) than conventional oils are. This business about "saturating the rings" is plain nonsense. When was the last time you saw steel get "saturated" with oil? For matching viscosity grades, it is generally accepted that a synthetic oil will provide somewhat better wear protection than a conventional oil.
Whether or not the improvement in protection justifies the increase in cost is another question altogether. I've run a sumpful of synthetic oil for one 7000-mile cycle (from 121k to 128k) of my girfriend's driving (97 Civic DX, 70% city driving), and oil analyses conducted along the way showed that the oil was holding up well. I've not attempted the same experiment with a conventional oil, as each analysis was about $35, so I can't directly compare results.
I personally prefer to use Mobil 1 synthetic oil in my gf's car, and whatever is cheap @ the auto parts store in my car (88 civic hatch). I don't bother with any of those silly engine additives.
Old 12-08-2002, 12:26 AM   #14
lapspec
Talking Book
I do not own the book it is just a link to the site. I do not have access to passwords. This is a copyrighted publication therefore it is up to the owner of the book to distribute it freely or not. Sorry
George J Lapchak
Bookmarks
Search this Thread:
