| Latest | 0 Rplys |
WIP - Motorsports Post topics for any "Work In Process" motorsports vehicles in this sub-forum. |
02-26-2016, 05:11 PM | #31 | |
Re: 1968 McLaren M7A, Bruce McLaren. Model Factory Hiro, 1/20.
Hi,
Thank you Weld lines are finished on the right side of the exhaust and left was redone. Few heat stains added. Weld lines are also made on the 2 in 1 tube. Pics of the sub assembly: Voilà. Pascal |
03-04-2016, 04:23 PM | #32 | |
Hi,
Started to work on the instrument panel and tachometer/tacho connection. Angle gear is made of 2 parts of brass connectors, filed down and soldered. Not the best, but not too bad due to the fact that the part diameter is 0.7. The genuine hole in the tachometer is drilled with 0.5 bit, then filled with 0.5 lead wire. Pascal |
03-05-2016, 05:21 PM | #33 | |
Hi,
Dash board painted with Flat Black ZP: Front dampers done: Stub axle modified: ... then burnished: Same for the center of the wheels: Pascal |
03-06-2016, 03:58 PM | #34 | |
Hi,
Small progress on the dash board. Stainless steel pop rivets cut and installed. A little square bracket is fastened to the right side in order to hold the accelerator cable. C'est tout. Pascal |
03-07-2016, 05:38 PM | #35 | |
Hi,
Still progressing on the Roooaaaarrring Papaya. Dashboard is finished and instruments are installed: Accelerator OK: I've tried to do the stitching by myself instead of applying decals: In the cockpit. A light weathering is started on the seat: Dry fitting: Voilà. Pascal |
03-12-2016, 04:46 PM | #36 | |
Hi,
Time for the clear coat: Modification for the wing support: Shoulder straps done too: More soon. Pascal |
03-15-2016, 11:27 AM | #37 | |
AF Modelrater
Great work - keep the updates coming!
03-19-2016, 06:55 PM | #38 | |
Hi,
Thanks. Small progress with the body installed and some work on the pipes with rubber connections and clamps. bracket for the brakes fittings Few details for the calipers (from the MFH M19). Test fit More soon. Pascal |
03-22-2016, 05:44 PM | #39 | |
Hi,
Front end of the McLaren is still progressing and almost done. Pascal |
03-24-2016, 05:02 PM | #40 | |
Hi,
Work on the rhodoïd windshield of the M7A: - cut, - drilled, - Black gasket painted and a color test Voilà. Pascal |
03-25-2016, 03:42 AM | #41 | |
Your work is awesome,Pascal!
Alessandro |
03-25-2016, 12:49 PM | #42 | |
Damn...
ianc |
03-25-2016, 04:51 PM | #43 | |
Hi,
Thank you very much guys! Small progress on the Roaring Papaya: Voili, voilou! Pascal |
03-25-2016, 10:45 PM | #44 | |
Incredible. Beautiful work. What a pleasure looking at these pictures and the intense detail work.
03-26-2016, 03:34 PM | #45 | |
Beautiful work!
