07-10-2004, 11:24 PM | #1 | |
high flo cat
I just put on a ceramic header on my 2001 Accord and relocated the O2 sensor. I have heard of people splicing wires to make the harness longer, but this is not needed. If you trace the wires back to the fire wall you can run the harness down from there to the header O2 sensor location.
Here is my problem. I bought a figh flow cat and there is no port for the sensor. Any suggestions? |
07-19-2004, 09:38 AM | #2 | |
Re: high flo cat
You could drill and tap a whole in the pipe directly after the cat. You could also just drill a whole in the pipe, and weld the right sized nut onto the pipe to avoid having to do the tedious task of tapping an exhaust pipe. Depeding on how the cat is you may even be able to drill into that and get a hole that will serve the purpose you need it to. Anywho, good luck.
Jake |
07-19-2004, 09:57 AM | #3 | |
Yeah you could do that or u could leave it like u had it.... It is what u think not what other people think....
07-29-2004, 11:45 PM | #4 | |
Re: high flo cat
or just get rid of the pos.... i dont even have one.. just a waste of time and power
Thread Tools | |
