11-20-2016, 06:34 PM | #1 | |
Question about updated front axle seal on 2003 silverado
I have to replace the axle seals and pinion seal on my '03 Silverado. I've had the seals for a couple years, haven't got around to doing them, they have only been seeping, you know typical mechanic, always fixing other peoples vehicles and not their own.
I noticed all three had puked out and my diff was low a litre, so I figured it was time to change them and clean the vent. Couldn't remember which ones they were in my pile of spare parts for like 4 different trucks all different body styles and years. so I got the part number from the dealer, they gave me 22761722, didn't have that one, but I have seals 12479012 and 15801507. did a search online and 12479012 updates to 15801507 and finally to 22761722. apparently 22761722 covers from 1997 to 2015. doing some reading online, the 22761722 is a 2 piece seal and there have been problems with it in pre 2007 trucks with it leaking and should use the 15801507. so I guess my question is, has anyone experienced problems with the newest updated one, should I return them and just use the other ones. I know I have changed them in a '15 and the thing came apart with half on the axle stub and half still in the diff. I never had that problem with the older 1 piece seals.
2003 Chevrolet Silverado 4.8l w/4.56 gears 2002 Chevrolet Silverado 5.3l 2001 Chevrolet Silverado 6.0l eclb |
11-21-2016, 11:29 AM | #2 | |
Re: Question about updated front axle seal on 2003 silverado
I have installed several of the updated seals and have had no repeat visits for leaks. Be sure to install them in the correct direction. There is a small stamp on them that says :air side", that side faces out.
11-21-2016, 03:15 PM | #3 | |
many years ago I had some weeping at those points all 3 of them on the front diff. input and the 2 outputs. 2000 silverado 4WD. I do change the diff fluids often .. when new . the front diff it was not looking all that good on the gear oil so I changed it often like 5k miles . when I noticed after 20K miles that the seals where weeping not dripping I added 1 OZ of engine oil stop leak made by BARS.
been about a decade 175K miles still looks good. every time I do the gear oil change I add it in .. do the drive train 40K miles no problems but new the front diff had a wear / break in issue so I replaced the front diff gear oil 3X the first 20K miles. using the vin# I would guess you should have no problem getting parts but GM is a screwed up company now so it is possible they lost all the data on your vehicle in the Bankruptcy . I just bought a brake line set for my truck at dealer ship one of the 5 brake lines was the wrong one.. must be a china communication problem.. |
