Go Back   Automotive Forums .com Car Chat > Hyundai > Accent | Verna
Old 05-31-2013, 09:45 PM   #1
michael6390
wheel bearing to replace??
brakes that arent seized but wheel nuts very hot and car has lack of power
wheel bearing to replace? thanks
michael6390 is offline   Reply With Quote
Old 05-31-2013, 10:38 PM   #2
gmtech1
gmtech1's Avatar
Re: wheel bearing to replace??
Do the wheels spin freely when they are in the air?
gmtech1 is offline   Reply With Quote
Old 05-31-2013, 10:50 PM   #3
michael6390
yes, no problem. caliper and pads ok
Old 06-01-2013, 02:37 PM   #4
jamesslcx
It could be bad brake lines. What year is the vehicle? How many miles?
jamesslcx is offline   Reply With Quote
Old 06-01-2013, 05:02 PM   #5
michael6390
hyundai accent 1997 with 72000 miles
Old 06-01-2013, 06:18 PM   #6
jamesslcx
Michael, any kinds of noises such as roaring while going around turns?
Old 06-02-2013, 10:27 PM   #7
michael6390
no nothing special
thanks
Old 06-03-2013, 01:19 PM   #8
jamesslcx
No noise of any kind probably rules out wheel bearings. Probably caliper pins are rusty causing the brakes not to fully release or bad brake lines.
Old 06-03-2013, 07:59 PM   #9
michael6390
usually on a car, is it normal that wheel nuts become hot? but not to burn fingers, right?
Old 06-04-2013, 12:42 PM   #10
jamesslcx
Michael, they can get pretty warm but if they are hot enough to burn you that's another story. When you raise the vehicle and spin the tires do you feel some resistance? A little is ok.
Old 06-06-2013, 05:37 PM   #11
michael6390
no all is ok. I took time to see all the break system and wheel bearings. on the passenger side, castle nut for bearing was unscrewed and since I screwed it some noise when I'm running with the car.
went to see mechanic. no oil contamination, no overheating. the only one thing that could be is master cylinder that not working well.
thanks
