Go Back   Automotive Forums .com Car Chat > Engineering/Technical
Engineering/Technical Ask technical questions about cars. Do you know how a car engine works?
Thread Tools Search this Thread
Old 04-20-2003, 07:19 AM   #16
ivymike1031
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
one with two turbine stages driving two compressor stages via concentric shafts. Somewhat similar to the compressor and turbine stages on a gas turbine engine.
I don't think they're in use in vehicular applications at this point, but perhaps in 5-10 years.
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
ivymike1031 is offline   Reply With Quote
Old 07-03-2003, 09:17 PM   #17
gtpornstar
Send a message via ICQ to gtpornstar Send a message via Yahoo to gtpornstar
I may be wrong but are you sure your not confusing twin entry with twin scroll ? What you have described to me here sounds like twin entry.
Twin scroll as I understand it -
The scroll area dictates lag, the larger it is the more it flows up top but the more laggy it is. At low rpm's there is less exhaust gasses flowing out the exhaust and hence is harder to spin the turbo, so a smaller port is used (only one of the exhaust ports are open), after a certain rev range or boost range, an actuator opens the second exhaust port to the turbo allowing more gases to enter and spin the turbo.
The idea of the twin scroll is to minimize turbo lag.
As I said, I may be wrong .....
Originally posted by texan
the twin scroll is just a more advanced tubine housing design that helps to enhance exhaust gass energy utilization while minimizing ehxaust manifold backpressure and hence potential for reversion.
Think of your average inline 4 cylinder. Ever notice how in 4-2-1 headers they always pair cylinder 1 with 4 and cylinder 2 with 3 when merging the 4 pipes into the 2 secondaries? The basic firing order dictates that pairing these cylinders together will give the longest possible gap between exhaust pulses traveling through the pipes, thus enhancing flow while minimizing reversion. The twin scroll operates with the same basic principle in mind: keep the cylinders firing into an exhaust pipe that isn't already stuffed full of exhaust from an adjacent cylinder. With turbo cars this can be especially important as at higher RPM exhaust backpressure is usually significantly higher than atmospheric pressure, and often higher than intake manifold pressure as well.
So the twin scroll creates two exhaust paths instead of one, allowing for that increased separation in exhaust flow that is key to keeping everything from stacking up behind the turbo and causing reversion. It also helps to preserve the exhaust velocity of each pulse by offering a smaller overall volume to hold each one, so the turbine impeller is more easily spun up by a given total amount of flow than an equivalent single scroll design. Or at least that's the theory behind them. Answer your questions?
gtpornstar is offline   Reply With Quote
Old 07-04-2003, 06:31 PM   #18
454Casull
I've never heard of that which you describe, but it does sound like it would be effective.
However, when I first read that, I thought you were talking about a standard twin-scroll turbine /w variable-area entry ports. That would have the benefits of less backpressure (due to the separate entry), and the variable size of the entry ports allow the velocity of a lower volume of exhaust gas to increase (increasing low-RPM efficiency).
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
454Casull is offline   Reply With Quote
Old 07-05-2003, 05:17 PM   #19
gtpornstar
Actually that is what I was trying to explain
Old 09-17-2003, 05:02 PM   #20
454Casull
Re: twin scroll turbo...
Variable vane turbos pretty much do what we were discussing.
Old 09-19-2003, 09:36 AM   #21
SaabJohan
The name "twin scroll" is used for both "twin entry" and "variable entry ports".
http://www.egarrett.com/technology/t...&l2id=2&l3id=1
SaabJohan is offline   Reply With Quote
Old 09-20-2003, 12:20 PM   #22
454Casull
I don't see anything in that page that refers to variable entry...
Old 09-21-2003, 04:32 PM   #23
SaabJohan
Re: Re: twin scroll turbo...
That's because there aren't any info on that page about variable entry.
But what it does explain is what twin scroll means, twin scroll is just a diffrent name for twin volute or in the case of turbine houses twin inlet (in the compressor the volute is the outlet). The use described on that page is the most common but it can of course be used to vary the inlet speed into the turbine, however since we have VNT we can use that instead, which I think is also a much better technology.
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
Bookmarks
Search this Thread:
