Old 08-18-2004, 04:03 PM   #16
94tegRS
94tegRS's Avatar
Re: b21A1 swap in a 87 si
Originally Posted by mikeymackinon
hi i drive a 91 prelude and the b21a1 motor has a lot of balls what ppl dont think about is that its 140horse power with 135foot pounds of torque thats really good power all the way through every rpm but the b21 does eat oil i know i blew one up and had it rebuilt and modded it putting out 190hp with no turbo yet the motor was designed to be turboed the if you look at the set up of a 91 prelude the cold air intake is really complex and when you remove it their is a lot of room for a turbo and intercooler their is also room to install an after market air intake if you move the battery to the trunk you can use a 94 integra after market intake (you need to cut some off) they are about $35 CAD to yor door step off ebay but about the b21 it tranny is really shity in USA in Japan it uses the Type R Integra Tranny with LSD thats what causes the motor to go because the line loose pressure and the tranny slips then the motor eats oil after time and then it blows (you can install a Type R Integra Tranny but it need a lot of work, not recommended) the motor eats a lot of oil because of the cooling system its a bad designe it has 2 fans one is an eletrice and cools the rad not the block when the car is off but what it should have also doen is ran the water pump so if you have a b21 install upgraded rad and everything else like the fan or go all out and install an intercooler then it wont eat oil also the oil pan is in a bad spot the car is really low to begin with and ppl lower it more so the plug on the oil pan hits the road and the threads rip causing it to leak "fuck" thats what happened to me and my fuckin engine blew, im still pissed and that was 4yrs ago the b21 has a low compression ratio because of its designe to be turboed i have been told it puts of 250hp when turboed and N/A (ZEX Kit) [ think about it b21 = 140 shouldnt it be b21 = about 210hp ] [ b17 = 170hp (civic sir)] when an eng has vtec that a form of a turbo from honda because trubos kill engines also ppl drive them to hard honda uses vtec instead of a turbo because it save gas and repair costs honda no. 1 deally is fule e-conime so 93 integra gsr 1.8 (vtec) = 160hp high compression 91 prelude 2.1 (no vtec) = 140hp low compression but if you drop a turbo in it = 190hp - 210hp high compression think about the h22 from the 2001 prelude the type s 2.2L= 223hp vtec thats type s not the s model 2.2L = 200hp vtec the type s is in japan ok so in a nut shell b21 is good if you turbo it and install an intercooler if not check your oil and coolant every week but this becomes expensive and you should have bought an h22 because it about the same price as a b21 and doesnt need a turbo or an intercooler also it has more hp to begin with, and you could always trurbo the h22 and have even more hp (you do the math) so if you turbo it need an intercooler if you add hp you need to upgrade your brakes the Type R integra brake fit but as for 87 its going to be tight and you will need to do some welding for the eng mounts to fit this is all i know for more info go to prelude3.com and go to the links mustard cat has a lot of good info about early gen preludes good luck and lude for life (the integra is a much easier car to do up the just seems to be more parts witch sucks for prelude lovers also the engine is a better design the 92 (gs) 1.8 = 140hp (no vtec) i dont recommend integra/civic swaps to preludes because the engines in preludes lean back causing less stress on the syncro in the tranny. syncro spin all the gears at the same speed allowing smoother shifting but they are not a durable as a b17 tranny pro vs. con) - mikeymackinon
dude you aint got a fucking clue what you are talking about, VTEC is nothing lie a turbo at all, it lets the engine draw more air in, turbo FORCES ALOT more air into the engine, and the trannny causes the engine to burn oil because the line loses presure and the tranny slips. well how does a 5 speed tranny slip, autos slip and fluid pressure in them to shift and stuff, but oin a 5 speed the clutch slips is the only tihng thats gonna slip, unless you chew every tooth off of a certain gear or something. and no the B21 shouldnt be 210HP, the B18 is not, the C5 is higher than 100/liter, the C1 is a bit lower, the B16 can be equall, lower or higher depending on country it came from. the K20 in the base is 160 and in the type S is 200, you cant say an engine should have thois msany HP because 100/liter is the standard, its not. also the way the engine leans hasnt a fucking thing to do with the synchro wearing you damn stooge. the synchro doesnt spin all gears at the same time, it gets the gear and the input shaft (I think, not sure what parts it gets moving exactly) spinning at the same speed before they engage as you shift. and no engine in any honda has been "BUILT FOR TURBO", if itr was built for turbo it would come with a turbo, honda foesnt boost their cars, I doubt they ever wil form the looks of it.
ban this clown, he just gave a years worth of dumb ass information.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
94tegRS is offline   Reply With Quote
Old 08-18-2004, 05:00 PM   #17
mikeymackinon
Angry
type s prelude h22 not type s rsx k20 i know that and the 87 prelude is an an auto didnt you read the original message or did you rip in to me instead of trying to help anyone "ass clown" but what do i know i only rebuilt my own engine and now drive a 97 lude and working a 240sx to silvia s14 conversion with a sr20det engine, have you ever even changed your own oil, ya thanks. as for the k20 2.0L = 200hp so shouldnt a b21 2.1L = 210hp but you did get me on the synchro 'whops' and i said vtec is a cheep version on turbo not vtec is turbo. the way the engine sits does matter because the engine and the tranny sit on rockers and shift in a pair if the block sits in the wrong direction it causes stress on the tranny and they kill one another also h22 are to much power for a civic body design and cause the chassy to warp so if you change the engine also swap the tranny. and i like that ding on the front of your integra nice work, if you talk trash about me again ill kick your dick in the dirt and smack your mouth loose, ok tuffy, so hop along done done because your done. - fuckin' mikeymackinon
mikeymackinon is offline   Reply With Quote
Old 08-18-2004, 05:07 PM   #18
alphalanos
you idiot displacement is not proportionate to horsepower!!!
And VTEC ISNT LIKE A TURBO!!!
alphalanos is offline   Reply With Quote
Old 08-18-2004, 06:52 PM   #19
94tegRS
94tegRS's Avatar
HAHA mikey youre an idiot. I didnt say it was a K20 in the prelude, it was a reference to your "this engine should be 210HP because itís a 2.1 liter" bullshit you wrote. the prelude is an H22, 2.2 liter, obviously its not a K20 since those are 2.0 engines. and you were the one talking about synchros and the JDM ITR tranny w/ LSD. I didnt know ITRís came with an automatic, sorry! oh wait I still donít think they did. and even if an automatic tranny slips, how the hell does that cause the engine to burn oil???
and what the hell are you talking about here?
"im still pissed and that was 4yrs ago the b21 has a low compression ratio because of its designe to be turboed i have been told it puts of 250hp when turboed and N/A (ZEX Kit)"
youve ben told it puts out 250 HP when turboed and normally aspirated. I REALLY hope you mean 250 when boosted and 250 when built NA or I really feel sorry for you. and N02 is sorta considered FI in a sense, so its not technically NA right there, you inject N02 which becomes heated and releases/FORCES more air to be in the cylinder than would normally be in there without it. and if it is built up NA and has the same power as it does when TC'd something is wrong, turbocharged should yield you way more power than NA, and especially across the whole board, maybe you have the same peak number but thats not all that counts, I donít even think youd have that though.
another thing, the fan pulls air through the radiator, and thats MUCH MUCH MUCH better than blowing it across the block. and nobody cares that it isnt blowing at the engine when the cars off(although it does somewhat since the air doesnt get through the radiator, then through the fan and just STOP dead right there. when the cars off, it isnt going to get hotter so theres no point in having fans blowing all over it. but when the cars sitting idling, what do you think would be better, water INSIDE the engine pulling heat from the engine and being circulated through to the radiator, being cooled and going back to rob more heat from the engine and then come dissipate it to the radiator which gets cooled by the fan and this goes around in a big circle continuously, or the hot water just keep getting hotter and a fan blowing at the block on the outside trying to cool the cylinder walls and everything INSIDE the engine where itís the hottest. when driving sure you donít need a fan, but idling you DEFINITELY need a fan.
and you say this,
"cooling system itís a bad designe it has 2 fans one is an eletrice and cools the rad not the block when the car is off but what it should have also doen is ran the water pump" ,
like you think that all the other cars have water pumps that keep pumping the water through after youve turned off the car and walked away, which, well, cant happen since its driven off the engine and if the engines not running, the pumps not spinning. maybe there is some cars out there with electric water pumps but I havent ever heard that before, not tp say that means they arent out there but A LOT less than mechanical ones for damn sure.
"1 deally is fule e-conime so 93 integra gsr 1.8 (vtec)"
first what the hell does 1 deally is fule e-conime mean???
2nd the 92-93 GSR's had a B17A (1.7 liter), 94 and up are the B18C1's
I love this one
"ok so in a nut shell b21 is good if you turbo it and install an intercooler if not check your oil and coolant every week"
so if I turbo my car, as long as I put an intercooler on it I donít have to check on things at all, but if I donít boost it I need to check my oil and water every week? only thing you could have meant different is maybe if you donít intercool it then check your water and oil every week, but you know the intercooler cools your air, which gores right into the engine, mixes with fuel, gets ignited, gets HOT and then still gets your turbo DAMN hot anyways, so either way the turbos gonna heat your oil and or water, depending on what turbo you got and how its bearings are cooled.
"2001 prelude the type s 2.2L= 223hp vtec thats type s not the s model 2.2L = 200hp vtec "
both of those have the same 200HP 2.2 liter engine. the type SH has 200 HP and the base has 200HP.
I could basically prove you wrong on EVERY SINGLE statement you made in your WHOLE ENTIRE post.
current
history:
Bookmarks
Search this Thread:
