#136
Re: Ford Escort RS1800
![]() want !!!! |
#137
Thanks guys I am very excited about the wheel/tires myself. I can't wait to see the castings. I wish I could take credit for them but Fireball Modelworks did the hard part. I just provided reference and guidance on what they should look like.
Motorsport Modeling |
#138
I want these too
![]() Kimmo |
#139
Strut brace fabricated and held in place with temporary pins.
![]() Front infill panels.
#140
The kit glass is ridiculously thick, nearly .070"
![]() I will replace it with some .010" clear sheet. ![]() When the glass is installed I hold it in place with a .015 headliner panel.
#141
Fabricated the water inlet for the engine for some shaped rod, flat sheet and a photo-etch header flange.
#142
Replaced the out of scale header flange and added mounting pins.
#143
Nice work on the glass parts, can't believe how thick they were
Steve Noble |
#144
Fantastic work JC, love the level of detail attention! Bravo!!
#145
Thanks Steve & Jeremy.
Here I have fabricated motor mounts. ![]()
Motorsport Modeling Last edited by afxracing; 01-26-2015 at 06:56 PM. |
#146
The way the kit is designed you mount the engine to the cross member then install this assembly in the chassis. I like to repeatedly test fit everything so that method does not work for me. I came up with a way to mount the engine without the cross member in place.
![]() ![]() Looks bad with the engine out but is completely hidden when the engine is installed.
#147
Belkits is gonna make a brand new Mk1 in plastic
Paolo - LoveGT40 Modelworks website www.alsoldatino.com my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber FB: https://www.facebook.com/alsoldatino |
| The Following User Says Thank You to lovegt40 For This Useful Post: | ||
afxracing (01-28-2015)
#148
Thank you Belkits
That is must have kit =) |
#149
The roll cage in the Belkits' MkI shows an angled bar beside each door. I haven't been able to confirm if the MkII had these door bars - does anyone know?
The Belkits also shows a diagonal bar behind the main roll hoop - not sure this is correct for the MkI or the MkII.
#150
I think so beside door could be inclined bars. Diagonal brace behind the protective frame probably was not. But it was different in each car.
