HELP! '00 328i, NO MANUAL! how do i...jjd228 04-19-2003, 05:32 AM just bought a 2000 328i but it didnt come with a manual. i downloaded one from bmw but then found out that the radio has a seperate manual? i have a million questions, but first, how do i set the time??? i cant figure it out for the life of me. ARR41779 04-19-2003, 05:49 PM not sure if the 2000 and 2003 are exactly the same, but most likely. press the button on the end of the turn signal stalk until the time is displayed at the bottom of the inst. cluster, then turn the rod that sticks out of the inst cluster. Hope that helps! ask about anything else you want to know, be happy to help if I can. FUN2DRV 330 Ci 04-19-2003, 08:29 PM The previous suggestion is right. The clock in the instrument panel and the one in the radio are one and the same. When you adjust the one in your instrument panel, the one in the radio is adjusted automatically. One thing that you want to make sure that you have is the code for your radio. If you ever disconnect the battery in your car, you will need this code to reset the radio and unlock it. Good luck!! I'm also willing to answer other questions that you may have in the future. jjd228 04-20-2003, 04:26 AM thank you so much! ok, now... does the radion indeed have a seperate manual? or will it come in the car manual? and back to the radio... to the right of the main display window is a smaller window. it says "rds* pty" what is that all about? LOL... if i press the button on the pty side, the display says "none". if i press the rds side, the asterisk goes away. anyone know? and where do i get the code for the radio? FUN2DRV 330 Ci 04-20-2003, 10:55 AM OK, there is no code on these radios. I was confused with my VW Jetta. There is a RADIOPASS document that has some information requied in the event that your radio is stolen. There is a separate manual for the radio though. - RDS stands for Radio Data System. In areas where it is available, some station information will be displayed if RDS is selected. - PTY stands for Type of Program. Again, it refers to stations that can broadcast text information as part of their regular programming and can be displayed by the radio. - RND stands for Random Play. It only shows when you are playing CDs. Hope this helps! jjd228 04-20-2003, 11:35 AM beautiful. 1 more... on the steering wheel there is a phone button, obviously not used because i dont have the phone. but under that (or over, i dont remember) is an R/T button. whats this? ARR41779 04-20-2003, 04:47 PM R/T stands for Radio/Telephone. Although I don't remember exactly what it does, I do remember that it has no use with out a phone. jjd228 04-21-2003, 02:54 AM ok... under the rearview mirror is a red bulb looking thing. it never lights up or anything... what is it, how do i use it? :) FUN2DRV 330 Ci 04-21-2003, 07:23 PM Hi! That is called the "clown nose". Don't worry, you will get used to it, I don't even see it any more. That is the alarm indicator. If you have the alarm, it will blink when the alarm is activated. The plastic box in the middle of the roof panel is the motion sensor for the alarm. On a side note, I just got an M Sport Steering Wheel installed in my 330 Ci last Friday and it is like having a new car. It is the same steering wheel that comes in the M3. It was not cheap, but I'm really enjoying it. jjd228 04-22-2003, 03:41 AM does anyone know where i can get a manual for the stock radio? ive been told its seperate from the owners manual for the car. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
