Momo Hub For Airbag Equipped Teg?
grumpee
04-17-2003, 01:47 PM
Got a momo race steering wheel and wish to install it. No HUB though. Anyone out there with a AIRBAG EQUIPPED integra who had performed an install for an aftermarket steering wheel? Which hub should i use and where do i get it. And where in Melbourne can i get someone to fit it on for me. Thanks.:bandit:
grumpee
04-18-2003, 02:36 AM
Anyone out there with a TEG had installed a shortshifter? Will this bring the value of my car down when i sell it? Will the short shift screw up my gear box? Is it worth installing it? THANKS ALL!
Spunkymonkey
04-18-2003, 10:17 PM
Ummm....grumpee..what planet you on? It is illegal to change your steering wheel! because it is equipped with an airbag! It is the same on any vehicle that has an airbag in the steering wheel.
You could possibly get it changed to the momo ones from a DC2 type R integra (as they are equipped with airbag) however I wouldn't do it, as you'd have to get someone to do it properly and not *&^# up the airbag function on your car!
As for the short shifter, I don't see much point. The gear ratios are quite short as it is. Plus any mods won't make much difference to resale value...ie you will end up losing money on your modifications when you resell, better to return the car to stock if you are going to sell, and sell the other parts seperately.
kaoru-tochiro
04-25-2003, 11:39 AM
grind the hub off the original steering wheel and drill holes to bolt the MOMO into it, its as easy as 1, 2, 3. Illegal, Shmillegal, cops don't even pay attention if you have an airbag or not.
