Vibration in my jeep? Help
bandit_2008
02-18-2010, 02:48 PM
You seem to know alot about lifts and stuff? Maybe you can help me. I just bought a 2002 Jeep Wrangler, it has 32x11.5x15 on it and do not rub even in a binde. I think it has a 2" suspension lift, but I have a vibration in the rear. I replaced the u-joints and it is alittle better. It vibrates when I give it power. There is a spacer on the transfer case rock protector about an inch.( I think! the belly pan should bolt straight to the frame right?) There are some 1" square tubing between the frame and the belly pan. That means that the transfer case was lowered, like it should be. Do I need to lower it more or get a slip yoke for 2" lift? The vibration is worst at certain speeds to. I have even ordered new tires and will put them on next week.
fredjacksonsan
03-01-2010, 12:01 AM
At what speeds are you experiencing the vibrations? Are they consistently at that speed? Is it a rapid vibration that varies with speed?
