Our Community is 705,000 Strong. Join Us.
96 ford heater stopped
sweetthing110
01-25-2010, 07:49 AM
I have an 96 ford escort and the other day i just got in it turned the heat on it blew for a minute and stopped could it be the fuze.or ??? i think it may be a fuze but i am unsure everythinng else is worken in the car just that happen or could it be a fuze for the fan..
AzTumbleweed
01-25-2010, 09:49 AM
I just had this problem and it is common on Escorts. Go down to where the heater motor is and wiggle the wires around and see if it doesn't start working. If so, then you just have a bad connection. :2cents:
mightymoose_22
01-29-2010, 04:16 PM
It sounds like you mean to say that the blower motor stopped working, not that you aren't getting heat.
Your blower motor may be bad, and is simple to replace.
The switch on the dash may be bad.
The resistor between the switch and the motor may be bad.
There may be a bad connection/loose wire.
A fuse may have blown, and is simple enough to check.
