2005 Kia Rio With a P0170 Code
mreynolds
01-03-2010, 02:53 PM
I have a 2005 Kia Rio that I just replaced a head on and it will run great until it warms up the it will not idle correct and is pulling a P0170 code. Anybody have any diagnostic procedures for this code. Thanks
RahX
01-03-2010, 04:22 PM
Make sure the intake hose is on the throttlebody good and tight and it is not leaking.
mreynolds
01-03-2010, 06:04 PM
I have replaced the clamp and it still have the same problem.
danielsatur
01-03-2010, 06:10 PM
Check the rubber, plastic, and seals on your PCV system, and for unmeterd air leaks from the air cleaner box to the throttle body.
mreynolds
01-03-2010, 08:08 PM
As of so far I have not been able to find any vacuum leaks. I have double checked the intake gasket, hoses, and air intake system. It only has the problem when it warms up. It will also rev up to 3000 rpm's when idling from no reason. Any ideas. Thanks
