1993 Ram van replaced tranny now it wont start please help!!princessanona 12-22-2009, 09:58 PM Ok We just replace the tranny on our 1993 dodge ram van w318 with overdrive and it wont start..... please any ideas we really need this car running asap.... PLEASE HELP!! hundahunta 12-22-2009, 11:02 PM crank no start or no crank??. shifter adjustment, crank sensor problem, connector not connected alloro 12-23-2009, 01:30 AM Probably your neutral safety switch didn't get connected. If that's the case then your backup lights likely aren't working either. princessanona 12-23-2009, 08:20 AM Does not crank!! also where is the neutral safety switch and how can you check if its bad.... could it be a fuse?? the car was fine and driving no problems until my husband took out and replaced the tranny... hundahunta 12-23-2009, 09:17 PM the switch is usually on the transmission. have you also try to adjust the shift lever, could the starter solenoid wire be loose when the trans was removed.. alloro 12-24-2009, 11:33 AM Does not crank!! also where is the neutral safety switch and how can you check if its bad. The neutral safety switch is on the tranny and has a 3-wire plug going to it. It's located on the driver's side near the shifting arm. It's function is to prevent the starter from turning unless the tranny is in park or neutral. Of course if it didn't get plugged back in the starter would not crank. It's highly unlikely that you'd blow a fuse when changing a tranny since there are no hot wires down there that are related to the starter circuit. Everything I said is assuming that the starter was reinstalled correctly and all of the wires were properly connected to it. princessanona 12-31-2009, 09:40 PM You guys are so great... It was the shifter lever.... My husband adjusted it - we are now back in business I dont know what we would have done without you and your help.. Have a blessed new year.... Thanks again!!! alloro 01-01-2010, 05:03 PM I dont know what we would have done without you and your help. Probably taken the bus. :biggrin: Automotive Network, Inc., Copyright ©2013
