Timing Chain Issue
dbasler
12-14-2009, 09:09 PM
My son has a 1987 Buick LeSabre that has 85,000 miles on it. Car ran fine, then now won't start. I believe it could be the timing chain. How hard is it to change that?
HotZ28
12-14-2009, 09:14 PM
While possible, it would be very unlikely that a timing chain would fail @ 85K! Do you have spark & correct fuel pressure?
dbasler
12-14-2009, 09:18 PM
Yes, there is spark and correct fuel pressure.
HotZ28
12-14-2009, 09:19 PM
Check compression next.
dbasler
12-14-2009, 09:20 PM
The carb is not sucking the air in, it is blowing the air out and the engine cranks really fast.
HotZ28
12-14-2009, 09:24 PM
Well, with that said you may have a timing chain problem! It is about a 4-hr job removing the front cover & replacing the timing set. If you do the job, be sure to replace the tensioner; in fact, that may be the problem!
dbasler
12-14-2009, 09:25 PM
Do I need an engine hoist to do this?
HotZ28
12-14-2009, 09:31 PM
You will need to support the engine, either from the top or bottom, to remove the front mount.
dbasler
12-14-2009, 09:33 PM
Thanks for your help!
rustbucket
12-14-2009, 10:31 PM
My 87 Lesabre timing chain (actually one sprocket) failed at 93K miles. Even after replacing it, it would not start because some valves and rods had bent. I had to have the heads refurbished. Quite a big job.
JLKINSER1970
03-31-2010, 11:04 PM
Don't forget to line up the marks on the crank and cam gears before you remove the chain. Make sure you also put them back the same way they come off. Also, there is a magnet that rides on the cam gear. I would replace it since you are already there.
